Sat, Nov 23, 11:28 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Help: displaced water always changes when moving an object
Crowning ( ) posted Thu, 01 October 2009 at 3:58 PM · edited Sat, 23 November 2024 at 10:49 AM
Hello,
I hope the more experienced Vue users can help me here.
What I'd like to do:
  • create enormous waves
  • place an object so that the back of the object is inside a wave, the front comes out of that wave
What I did:
  • checked 'Displace water surface' in the 'Water Surface Options', so that I'm able to adjust the wave's height by hand.
  • moved my object partly into one wave
My problem:
  • whenever I move my object, all waves are completely re-computed and re-drawn, so my nice wave is somewhere else, and my object is either complete underwater, or not in the water anymore.
  • Rendering displaced water is VERY time consuming (even in 'Preview' mode on a 4GHz dual core machine), so even several hours of trial and error doesn't gave me an acceptable result.
Any ideas what to do?
silverblade33 ( ) posted Fri, 02 October 2009 at 12:40 PM
well unless you need a large expanse of water visible in render
hwy not use a terrain with a function to create waves, thus lower memory requirements as you can erase pieces of the terrian not visible in render which will reduce reosurces needed, and being a terrian, should be fixxed? :)
odd that the water is changing though
Crowning ( ) posted Sat, 03 October 2009 at 8:30 AM · edited Sat, 03 October 2009 at 8:30 AM
Quote - well unless you need a large expanse of water visible in render
Thanks for the suggestion, that's a thing I always wanted to try anyway, so I think it's a good time for it NOW :)
Found the reason: in the displacement function there's a time node (probably for animations).
Disconnect this node and the wave stays static. Easy fix.
silverblade33 ( ) posted Sat, 03 October 2009 at 2:01 PM
Ah, usually it's something simple but unexpected like that, good to know! ;)
