For this, the better is the envsphere from BB, you can find more infos here
http://sites.google.com/site/bagginsbill/free-stuff/environment-sphere
Génération mobiles Le Forum / Le Site
IDL in poser is light bouncing. its a way to simulate how lighting works in real life. light bounces around in the real world. plus IDL in poser is also able to use every texture and geometry as a lightsource. so if we have a box in our scene and the ambient is set to white then it will light our scene.
if people dont understand this with 100 articles on google then they shouldnt use it. i know i sound mean but there is enough info on this forum and on google. i doesnt get any easier then this. its light bouncing aroud. if we have at home a white wall then lets put our hand next to the wall. we will see a very small orange tint. its light bouncing from our skin on the wall.
IDL means indirect lighting.
Poser, vray, mentalray, blender, c4d, all have this feature, know as IDL or GI ... I post this cause many people use this feature with light set from store or freebee, they arent the most realistic !
IDL work like reflection, if you have nothing to reflect you scene look empty ...
I never see something in the world without an environment ...
Quote - Poser, vray, mentalray, blender, c4d, all have this feature, know as IDL or GI ... I post this cause many people use this feature with light set from store or freebee, they arent the most realistic !
even if you have no environment there still will be light bouncing.
I don't think that's what anthansius is saying, ice-boy. she said it would look empty, not that it wouldn't work.
I, for one, appreciate any info on IDL being shared, that way more people will learn to use it.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Quote - I believe she meant an infinite light to illuminate the top of the object (R2D2 in this instance). Generally, the direction from which the light is coming from.
I agree, but for this exemple is there too mani light to found the better direction of the inf light
Quote - The same scene with final render ... dont forget the env emit light, for that i put the emit at 50 % and the light at 50 %
Light
RT shadow
B 20
S 80
MB 0.2Render settings
B = 2
IC = 0
ILQ = 75
PS 6
MSR 0.2
Okay, another question. :)
The light is obvious.
Shadow Blur Radius: 20
Shadow Samples: 80
Shadow Min Bias: 0.2
The second, I'm guessing is the main render window, not Dimension3D's excellent render window.
Raytrace Bounces: 2
Irradiance Caching: 0 (?)
Indirect Light Quality: 75
Pixel Samples: 6
Min Shading Rate: 0.2
Just in case. :)
Now, you say you put the emit to 50% light at 50% -- I'm not sure where you set the emit?
Silke
Silke, for the light it'in the panel where you define the color the xyz position etc etc ...
For the envsphere, if you use the BB shader by defaut, see the altdiff it is white, white = 100% black = 0% ... 50 % = ? mid grey so 127,127,127 !
I set these settings for this scene, for another scene the settings may be differents !
I post somes other exemples later, poser is rendering since 3h am
For this example i use trocadero ( staying french :-) ) pluged in the ambiant_color, you can use the default settings of the envsphere, but i prefer using it, and the mini from p8 ... Dint forget to delete all the lights !
In the first render we have the ambiant light only ...
Switch to the auxcam and put it at x,y,z 0,0,0 and rotation 0,0,0 too ...
I set a large angle for more precision, like 15 mn, for a little help you can use the focus distance guide like the picture.
Look for the sun with the y and x orbit only, it's enough
The x orbit of the camera will be the negative for the light, here we have 26 for the camera, set -26 for the xrotate of the light ...
For the xrotate of the light add 180+the yorbit of the camera, here 180+113 so 293.
For this image i set the intensity of the envsphere to 0.8 and the light to 0.8 and some fresnel reflection refraction ... dont forget to add more bounce of raytracing when you have reflection/refraction, minimum 3 ...
The 4 color balls have the AMBIENT at 40.
NO other lights are used.
The middle ball, the roof, walls, floor have a Reflect in the Diffuse and the Reflection
The full series can be seen in the post about the P8 Glowing Effect, but here is the result :(click)
Cast shadows ON
Raytrace ON
Bounces 2
IC 10
IQ 50
Px 3
MSR 0.5
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Included a small test
Left Ball White reflect in duffuse gives just a reflected shadow
Middle ball White reflect in diffuse and in reflection gives a mirror of Aly
Right Ball White reflect in reflection gives ? not a lot actually
Dev
"Do not drive
Modulating reflections with the diffuse light node makes no sense at all to me, at least in real world terms. (That's why we should never use Reflect_Lite_Mult in the PoserSurface node, which effectively does the same thing to reflections).
Personally, I would avoid it for that reason alone.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Aha... so those two multipliers must operate on the Reflection channels themselves, no matter what you have plugged in to them.
I never use reflection maps, so I never understood what those multipliers were for. Now all is explained, thanks!
what I should be."
Murakami)
Reflect_Lite_Mult and Reflect_Kd_Mult make no sense, period, regardless of whether the reflections are fake (with a Sphere_Map) or real.
Consider - a scene with no lights, just two balls. One is glowing, the other is a mirror ball. With Reflect_Lite_Mult on the mirror ball, what color is it? Answer: Black.
Quote - ... make no sense...
Well, actually the original concept now makes sense to me. It was an easy way of making reflection maps (which would otherwise be uniformly self-lit) dependent on scene lighting in a somewhat reasonable way. I agree it makes no sense to do things this way nowadays.
Of course it won't work in bb's example scene; there is no diffuse light in the scene, so the reflection map is always multiplied by zero. But in reality an object that is visible (glowing) with no external lighting must itself be a light source, and with that light source correctly modeled in the scene the 'reflecting' ball would not be black.
what I should be."
Murakami)
Let me help you using IDL, too many people use this feature without knowing how it work ...
(Please dont answer)
