Thu, Feb 27, 5:27 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Poser Instal
overlas ( ) posted Sun, 22 July 2001 at 8:10 AM ยท edited Sun, 01 December 2024 at 11:55 AM
I have some problems with my CDROM in windows, I have access to contents only in DOS mode. So, my question is: can i instal the POSER4 trough DOS?
Jackson ( ) posted Sun, 22 July 2001 at 9:18 AM
No. What problems are you having with the CD in Windows?
mheldt ( ) posted Sun, 22 July 2001 at 6:39 PM
If your system is that far out of wack you should consider fixing it before adding anything.
shadowcat ( ) posted Sun, 22 July 2001 at 10:59 PM
Your disk could be dying, you may want to consider copying the whole disk to your hard drive to be safe. Do you have this problem with other CDs? If not, definately copy whole disk (if you can) while in Dos. I had a similar problem with a disk just before it quit on me altogether (due to scratchs) Another thing to consider is replacing the CD-ROM driver, they may be corupted in windows (maybe?) If it turns out to be a bad disk you could try contacting curious labs, they may send you a new one if your a registered owner and have a registration code.
