Wed, Feb 26, 9:45 PM CST
Forum Moderators: RedPhantom
Subject: P8 figure load times excessive
Dave-So ( ) posted Sun, 07 March 2010 at 12:48 PM · edited Wed, 26 February 2025 at 9:43 PM
why would it take more than 5 minutes to load V4 into Poser 8?
Not just her, but most figures.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
bagginsbill ( ) posted Sun, 07 March 2010 at 1:01 PM
Anti-virus software?
Just for comparison, it takes me 8 seconds to load V4 in P8.
geep ( ) posted Sun, 07 March 2010 at 1:36 PM
Check and see what else is running which may be consuming CPU power?
Just a thought.
cheers,
dr geep
OR ............... what BB said. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
Dave-So ( ) posted Sun, 07 March 2010 at 3:12 PM · edited Sun, 07 March 2010 at 3:13 PM
could be the AV ...
nothing else running other than AV and spyware stuff, plus all the background jung which I can't seem to get rid of in XP. 98 used to run pretty much clean.
8 seconds ...yikes. I need a new system too.
I'll go offline and shut off the AV and see what happens..
Thanks.
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 3:16 PM
what AV / Anti Spyware are you running?
can you do a Alt+Ctrl+Del and show us the Processes you have running?
Dave-So ( ) posted Sun, 07 March 2010 at 3:49 PM
processes ...way too many. I had shut off a lot before, such as the adobe updater so I could manually do that when I felt like it, but it is now back...but there are a ton...all of them do not show .. don;t have enough screen real estate to get all of them in one shot.
The capture of the processor resources...the use spiked for qyuite awhile when PSP was loading...I noticed, though, that every once in awhile the cpu would go up to around 30-40% ... appears something is accessing the net or something.
click on image for larger, of course
Dave-So ( ) posted Sun, 07 March 2010 at 3:54 PM
the rest ... that KHALMNPR.exe is interesting. I see a few others that could go as well, but it seems everything you install on your system wants to access the web.
bagginsbill ( ) posted Sun, 07 March 2010 at 3:55 PM
Oooh boy you have a mess there. Kaibach likes to chew on these. Fun fun.
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 3:59 PM
omgawd.
ok...! we can fix this.
while I write up a list of what to kill, please goto http://www.mlin.net/StartupCPL.shtml and get and install the Startup.CPL. for system maintenance on XP .
using that it'll be easy to turn off what you don't need loaded and there's a lot there.
Dave-So ( ) posted Sun, 07 March 2010 at 4:06 PM
ok ..first off...thanks for the help :)
I'm happy its saveable :)
startup.CPL is installed
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 4:30 PM
ok these are what I would remove / disable using Startup and what I know is perfectly safe and what you just don't need running all the time anyway.
Adobe_Updater.exe - Kill - Manual Update as this does not update that quickly
rhaphlpr.exe - kill - Rhapsody Helper for the subscription music service. I suspect you don't need it running all the time.. try killing it.
pdsched.exe - kill - Perfect Disk Scheduler. YOu don't need this constantly running.
wodupdsv.exe - kill - some update service. I'd kill it until more is known.
spysweeper.exe - kill - you don't need this running constantly. run a sweep every few days.
viewpointservice.exe - Kill - unless you are running "viewpoint media player' for some AOL items, KILL THIS. it is actually a mild spyware app.
psiservice.exe - Unsure - this is a copyprotection program. not sure what you are running that requires it.
psiservice_2.exe - as above.
photoshopelementsdeviceconnect.exe - Non Essential..personally I'd kill it.
pd9engine.exe - Kill - part of perfectdisk defrag. you don't need a defragger running constantly.
novacomd.exe - Phone app. I think you may need it.
kodaksvc.exe - unless you are sharing your Printer, kill.
jqs.exe - http://techsalsa.com/what-is-jqsexe-and-how-to-disable-it/
photoshopelementsfileagent.exe - only needed if you use the Elements Organiser to track files. if not, Kill.
viewmgr.exe - Kill
ssu.exe - Kill - Spysweeper. you don't need this running constantly. run a sweep every few days.
incdsvr.exe - Nero Bloat. Kill.
wrconsumerservice.exe - Spysweeper. see above.
khalmnpr.exe - Part of the Logitech Mouse software.
corel photo downloader.exe - Kill.
spysweeperui.exe - Spysweeper, see above
itouch.exe - Logitech Keyboard software. safe.
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 4:36 PM
oh I forgot.. once you've killed them off, reboot.
you should see a huge improvement in bootup speed and speed in general.
vilters ( ) posted Sun, 07 March 2010 at 5:13 PM
I would run something like;
Advanced systemcare free (free) One click maintanace, just click the "care" button in the middle.
Glary utilities (free) One click maintanance on top of the screen.
Optional ; Ccleaner (free)
Install and run , in that order.
Just pay atention to Glary utilities as it "cleans" skype a little too good.
But you can uncheck those lines if needed.
The first 2 also have a lot of usefull tools to check Windows, memory etc.
System would be as good as new.
Very carefully check the "options" of a lot of installed programs.
Do you realy need all spyware inspectors? One can get? Running all the time?
Te first 2 , manually, once an evening, do the job quite well.
Good luck
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 5:20 PM
hold on there.
one step at a time please. let him clean the list out first before adding anything else to the confusion.
vilters ( ) posted Sun, 07 March 2010 at 5:25 PM
Indeed, one step at a time.
Just wanted to help, and show how I keep my systems clean.
Dave-So ( ) posted Sun, 07 March 2010 at 6:18 PM · edited Sun, 07 March 2010 at 6:31 PM
ok ...Thanks ...
I will get started. I can feel my hair blowing in the wind already.
Zooooooooooooooom
edit: just killing spysweeper speeded my email about 10,000 times. browser, ie8, still pretty slow.
I can't find most of that stuff in the list anywhere to turn off though.
Khai-J-Bach ( ) posted Sun, 07 March 2010 at 7:24 PM · edited Sun, 07 March 2010 at 7:27 PM
check all 3 tabs on Startup.cpl
some may not appear.. we'll get it tho. one step at a time.
thinking about it.. can you screengrab each tab?
Dave-So ( ) posted Sun, 07 March 2010 at 9:59 PM
will have to do it more tomorrow ..sorry...
need to get to bed..up at 4:30am
Lucifer_The_Dark ( ) posted Mon, 08 March 2010 at 3:24 AM
Also if you're feeling brave check out www.blackviper.com/ they have a nice list of all the services that run in the background & how they should be set "disabled, manual, automatic" ,choose the safe option. No Windows user should be without that link.
Windows 7 64Bit
Poser Pro 2010 SR1
Khai-J-Bach ( ) posted Mon, 08 March 2010 at 3:25 AM
thats the next step! lol down in front! throws popcorn at Lucifer
Lucifer_The_Dark ( ) posted Mon, 08 March 2010 at 3:47 AM
eats popcorn thrown by kaibach
Oh yeah before I forget, thanks for the StartupCPL link, it works on Windows7 X64 as well as XP. :D
Windows 7 64Bit
Poser Pro 2010 SR1
geep ( ) posted Mon, 08 March 2010 at 5:22 AM · edited Mon, 08 March 2010 at 5:23 AM
re: the throwing and eating of popcorn in the Poser Forum ... ROTFLMAO :lol:
BTW  - Please clean up your mess when you are finished throwing/eating because your Mother does not work here and I am sure that some of the popcorn did a "Drop to Floor." :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Dave-So ( ) posted Mon, 08 March 2010 at 5:49 AM
now there are pigeons all over the place ...
Lucifer_The_Dark ( ) posted Mon, 08 March 2010 at 6:41 AM
I don't know what it is about me that pigeons hate but they will insist on dive bombing me when I'm out, one actually bounced off my head a while back.
There is one in town that's very tame though, he only has one foot & has the (rather cruel) nickname stumpy, he'll take food right out of your hand.
Anyway that's enough about pigeons & popcorn, what was the thread about? I've forgotten. ;)
Windows 7 64Bit
Poser Pro 2010 SR1
Tashar59 ( ) posted Mon, 08 March 2010 at 5:16 PM
BM
Lucifer_The_Dark ( ) posted Tue, 09 March 2010 at 3:53 AM
So Dave how's your PC doing now? Load times improved? Resources less hogged than before?
Worried people need to know these things. ;)
Windows 7 64Bit
Poser Pro 2010 SR1
Dave-So ( ) posted Tue, 09 March 2010 at 5:45 AM
haven't had time to work on it. hopefully after i get home this evening.
Dave-So ( ) posted Wed, 10 March 2010 at 6:30 PM · edited Wed, 10 March 2010 at 6:31 PM
ok ..back . sorry for the delay, but RL beckons every once in awhile. here is the STARTUP program entrees. I can see a couple I can uncheck, but no where near the amount that is in my taskbox.
Khai-J-Bach ( ) posted Wed, 10 March 2010 at 6:40 PM
okies kill off the 2 in HKCU Run.
now you should be running a lot faster right now.
just gonna grab dinner then I'll see about the next stage.
Dave-So ( ) posted Wed, 10 March 2010 at 9:24 PM
somehow that corel downloader is active again.
yes, it is getting faster. too much stuff trying to access the web.
