Sun, Dec 1, 5:46 PM CST
Subject: Problems running python scripts
Hydra ( ) posted Mon, 08 March 2010 at 6:56 PM · edited Fri, 29 November 2024 at 12:09 PM
I have the Jasmina color and jasmina changer scripts but I cannot seem to get them to work.  I load the figure, go to the material room and hit the user defined button.  The color changer pops up, when I select it, a small window opens with a bunch of text and voila- nothing happens.  What am I doing wrong?  This happens every time I try to run one of these scripts either from the material room or from the file menu in Poser.  I am using Poser 7 btw.
Thanks.
Hydra
FrankT ( ) posted Mon, 08 March 2010 at 7:10 PM
knowing what the "bunch of text" is would be a help in figuring out what the problem is
My Freebies
Buy stuff on RedBubble
ockham ( ) posted Mon, 08 March 2010 at 8:43 PM
The 'bunch of text' is probably an error message.  Copy and paste it here, and
somebody will be able to tell what's going on.
My python page
My ShareCG freebies
Hydra ( ) posted Mon, 08 March 2010 at 9:00 PM
ya sorry about that.   I probably should have thought of that to begin with!
Here are the messages I get:
Traceback (most recent call last):
  File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedJasmina Changer.py", line 478, in ?
    MatDlg = MaterialsDlg(tk)
  File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedJasmina Changer.py", line 67, in init
    Label(self.NormalFrame, text='Color Selection(There may not be screen changes after applying.Please Render for the result.)', font=f).grid(row=0, col=0,sticky="w")
  File "C:Program Filese frontierPoser 7RuntimePythonliblib-tkTkinter.py", line 1790, in grid_configure
    self.tk.call(
_tkinter.TclError: ambiguous option "-col": must be -column, -columnspan, -in, -ipadx, -ipady, -padx, -pady, -row, -rowspan, or -sticky
Here is the other message I get:
  File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedJasmina Color.py", line 461, in ?
  File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedJasmina Color.py", line 76, in init
    self.tk.call(
I am using Windows XP.  I have Poser 8.0 installed on another drive but I find Poser 8.0 to be entirely un-useable.  I will leave it at that.
Thanks for your help!
Hydra
ockham ( ) posted Mon, 08 March 2010 at 9:07 PM · edited Mon, 08 March 2010 at 9:09 PM
This is a common problem.  In earlier versions of Python, "col" was permitted
as an abbreviation for "column".  Later versions were stricter.
Edit the file, changing each col to column
in these situations.  Look for lines that have both row and col, like
        self.ButtonFrame.grid(row=2,col=0,pady=1)
You'll probably have to make the change manually ... an automatic
find and replace will also change words like color.
My python page
My ShareCG freebies
bagginsbill ( ) posted Mon, 08 March 2010 at 9:08 PM
The abbreviation of col for column was deprecated since these scripts were written.
You have two choices:
1) Edit the script to fix the problem, which is easy, but requires care. (Requires that you have the script in source form, i.e. a .py file, not .pyc or .pyd.
2) Contact the author for an updated version.
If you're of a mind to fix it yourself, you have to find the offending line that says col=0 in it and change that to column=0.
This forum has removed the slashes in file paths, so it is hard for me to tell, but it looks like either JasminaChanger.py or Jasmina Changer.py, line 67, for the first one. The second one is JasminaColor.py or Jasmina Color.py, line 76.
Dang it - again ockham is too fast for me!
Hydra ( ) posted Mon, 08 March 2010 at 9:31 PM
Thanks guys!
Hydra
