Fri, Nov 29, 10:59 AM CST
Subject: What do you think is happening here?
craftycurate ( ) posted Sat, 08 May 2010 at 6:29 AM · edited Fri, 29 November 2024 at 10:06 AM
 I've mapped a texture map onto a cloth created using Blender cloth sim. I notice that in certain places the alignment of the texture does not follow the alignment of the polygons. I have tried the various relevant mapping modes, but I cannot change how it aligns.
See red areas in attached image: (click for full size)
Any thoughts as to what's happening, and how I might fix it? Is this an issue with Blender cloth sim, perhaps not creating normals properly?
Thanks
Richard
bigbraader ( ) posted Sat, 08 May 2010 at 6:43 AM · edited Sat, 08 May 2010 at 6:49 AM
My best bid is that you use the "faces" mapping, but you've probably already tried that.
Cool model BTW.
Lars "bigbraader"
craftycurate ( ) posted Sat, 08 May 2010 at 6:49 AM
 Yes, I've tried that, as well as "Automatic" and "Flat".
UPDATE: This also happens with a built in Vue object (table + tablecloth).
bigbraader ( ) posted Sat, 08 May 2010 at 6:54 AM
Try parametric, both in the effects "Object  - parametric" and the mapping, and downscale the texture map, but again you've probaly tried that as well.
Sue88 ( ) posted Sat, 08 May 2010 at 8:46 AM
 Before running the cloth simulation in Blender, I would do a planar UV mapping on the cloth object. Then run the simulation. This should retain the UV map and the texture should look more natural. I don't have Blender, but this is what I would do in the programs I use.
craftycurate ( ) posted Sat, 08 May 2010 at 9:53 AM
That sounds right - the UV map has to be deformed too. I felt it was something to do with UV mapping, but it's something I am only just learning.
Thanks
Richard
craftycurate ( ) posted Sat, 08 May 2010 at 10:12 AM
That's done the trick - thanks!
Richard
Sue88 ( ) posted Sat, 08 May 2010 at 8:18 PM
You're welcome. :) It looks great!
