Sun, Dec 1, 2:53 AM CST
Subject: Keeping the camera still
Apple_UK ( ) posted Sun, 08 August 2010 at 11:53 AM · edited Sun, 01 December 2024 at 2:52 AM
I've been trying a bit of animation with a scene containing two characters. When I select a character the camera position changes, then changes again when selecting the other. Could anyone tell me how to freeze the camera position please.
ShaaraMuse3D ( ) posted Sun, 08 August 2010 at 11:57 AM
 Have you selected the camera, and dechecked the "animating" box?
Apple_UK ( ) posted Sun, 08 August 2010 at 12:00 PM
I have done that Grappo but it still moves when change character
ShaaraMuse3D ( ) posted Sun, 08 August 2010 at 12:02 PM
 What you can do is to save the camera values and apply it to the camera for the other character, since it may use a different instance of the camera for the other character..
Apple_UK ( ) posted Sun, 08 August 2010 at 12:08 PM
Oh, thank you, Grappo will give that go :)
ShaaraMuse3D ( ) posted Sun, 08 August 2010 at 12:10 PM
 I did that when I had two cameras in the same scene (one character), and I wanted a move to originate from the same position, but have different endings.
markschum ( ) posted Sun, 08 August 2010 at 12:34 PM
what camera are you using ?
the face or hand cameras are using a "point at " to track the body part. The other cameras should not move simply be selecting a figure.
Apple_UK ( ) posted Sun, 08 August 2010 at 12:35 PM
I tried it. I zerroed all settings for both characters on all key frames but the camera still moves. Even when it has moved it stills says they are at zero on all the settings.
geep ( ) posted Sun, 08 August 2010 at 12:49 PM
Have you tried >>> *[menu] >>> * "Object" >>> Lock Actor" ... for the camera?... ? :blink:
Just a thought. 😄
cheers,
dr geep
;=]Lock
cheers,
dr geep ... :o]
edited 10/5/2019
Apple_UK ( ) posted Sun, 08 August 2010 at 1:21 PM
I zeroed main, aux and pose cameras with no effect, I'll try that geep, thanks
saibabameuk ( ) posted Sun, 08 August 2010 at 1:40 PM
 I think you might be using the face camera! when you then chose the other actor the whole scene changes, if you go to the main camera it will freeze the view.
However what do I know , I probably misunderstood the question in the first place.
Apple_UK ( ) posted Sun, 08 August 2010 at 1:44 PM
Saibameuk hit the nail right on the head :) It does not seem to matter wich camera you choose if it does not correspond with the one chosen in display. I selected main camera in display (It been face camera) now the problem is solved. Thank you for all your answers.
saibabameuk ( ) posted Sun, 08 August 2010 at 1:52 PM
OPPPS
