Wed, Feb 26, 7:06 PM CST
Forum Moderators: RedPhantom
Subject: V4 skins with realistic thick eyebrows?
Coleman ( ) posted Fri, 08 October 2010 at 4:07 AM · edited Fri, 13 December 2024 at 10:26 AM
What are the best V4 skins with realistic thick eyebrows?
cspear ( ) posted Fri, 08 October 2010 at 5:24 AM
V4 has a body part named 'Eyebrows' which seems to be set to invisible by default. You could make it visible and create a suitable alpha mask and texture for that.
Or you could combine an alpha mask with the base texture.
Or you could edit the original texture (save it with a different name) and apply that to V4's face.
I've used all of these techniques to create my own eyebrows.
PoserPro 11 - Units: Metres
Adobe CC 2017
Zev0 ( ) posted Fri, 08 October 2010 at 5:28 AM
  1. In my opinion, best bet is to edit the head image map in photoshop (colour and bump), then create a nice displacement to give them volume.
  2. (not sure if this will work) There is also the option of editing the brow morphs, maybe make them higher or wider?
My Renderosity Store
RobynsVeil ( ) posted Fri, 08 October 2010 at 8:02 PM
Do you have a tablet? I'd be doing similar to what CSpear suggests and draw your own... you can use one of the images above as a template/guide. You save your image white against black background as greyscale... then when you decide which hair you wish to use, you can apply a matching colour to your eyebrows.
Metaphor of Chooks
Cyberwoman ( ) posted Fri, 08 October 2010 at 10:12 PM
I agree that the best thing to do would be to edit the head texture (use of a tablet pen highly recommended). The Stephanie 4 download comes with a texture that has fairly thick eyebrows--not as thick as most of the ladies' in your pictures, but it seems to me like they're thicker than those on a lot of V4 textures. Maybe that texture might be a good starting point for modification?
~*I've made it my mission to build Cyberworld, one polygon at a time*~
Watch it happen at my technology blog, Building Cyberworld.
Coleman ( ) posted Sat, 09 October 2010 at 12:36 AM
thanks a lot for the suggestions everyone!!
I'll try out eyebrow brushes for photoshop.
