Wed, Dec 11, 1:39 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Rain scene in Vue
egalps1 ( ) posted Fri, 08 October 2010 at 10:13 AM · edited Tue, 03 December 2024 at 2:49 PM
I want to make a rain scene in Vue.Can it be done?
Thanks!
gillbrooks ( ) posted Fri, 08 October 2010 at 10:41 AM
There are several ways.  You could use alpha planes or for some really interesting rain and other weather try Wabe's Bad Weather at Cornucopia
http://www.cornucopia3d.com/purchase.php?item_id=5309
http://www.cornucopia3d.com/purchase.php?item_id=5099
Gill
thefixer ( ) posted Fri, 08 October 2010 at 1:23 PM
Or you could use the rain prop that comes with every copy of Vue..
Injustice will be avenged.
Cofiwch Dryweryn.
gillbrooks ( ) posted Fri, 08 October 2010 at 5:19 PM
There's a rain prop?  Now he tells me!!  I've never seen it - though I haven't really looked around the objects that ship with vue since version 4......
:blushing:
Gill
thefixer ( ) posted Sat, 09 October 2010 at 1:57 AM
Objects--Exterior---Nature..
It's very basic but it does the job most of the time depending what you want. It's essentially a cylinder you place in front of the camera, adding more of them and changing the orientation gives different effects..
Cofiwch Dryweryn.
gillbrooks ( ) posted Sat, 09 October 2010 at 7:29 AM
Oh yes there it is!  Right next to the beam of light I've never used either :lol:
I'm sure that could be improved upon to be quite a useful prop 😄
Gill
thefixer ( ) posted Sat, 09 October 2010 at 4:03 PM
Yea I've never used the light beam either, I have used the rain prop though..
Cofiwch Dryweryn.
perilous7 ( ) posted Mon, 11 October 2010 at 8:23 AM
Wabes props are great to use and well documented too :-)
 A cleaved head no longer plots.
http://www.perilous7.moonfruit.com
ChrisV ( ) posted Tue, 19 October 2010 at 6:38 PM · edited Tue, 19 October 2010 at 6:46 PM
> Quote - Objects--Exterior---Nature.. > It's very basic but it does the job most of the time depending what you want. It's essentially a cylinder you place in front of the camera, adding more of them and changing the orientation gives different effects..
Hi,
I had this very same problem which I raised on this forum a few months ago.  The rain cylinders (I use four of them nested) work very well. Here is an example of what they look like in a scene
Many thanks fixer!
ChrisV ( ) posted Tue, 19 October 2010 at 6:43 PM · edited Tue, 19 October 2010 at 6:46 PM
And here's another simple one set on a foggy wet day
gillbrooks ( ) posted Wed, 20 October 2010 at 7:12 AM
Excellent examples 😄
Gill
