Sun, Dec 1, 4:57 AM CST
Subject: Any one know why these squares appear on render?
saibabameuk ( ) posted Sun, 10 April 2011 at 1:31 PM · edited Sun, 01 December 2024 at 4:49 AM
basicwiz ( ) posted Sun, 10 April 2011 at 1:37 PM
Looks to me like the render did not finish. When you did this screen cap was there still a red "X" in the camra icon at the right top of the picture frame?
bagginsbill ( ) posted Sun, 10 April 2011 at 6:27 PM
That is an old bug I thought was fixed. Are you up to date on Poser service release?
saibabameuk ( ) posted Mon, 11 April 2011 at 4:22 AM
As far as I know the render finished and I had exported saved the 200 frames it is an intermediate problem some frames a free from the squares.
Thanks for coming back to me , I am running Poser 8   8.0.311793
Strangely enough I have a copy of 2010 and have not used it yet would this apply in poser pro 2010 I wonder?
bagginsbill ( ) posted Mon, 11 April 2011 at 7:22 AM
You're P8 is up to date then. If you re-render an afflicted frame, is it the same? If you can reproduce this, you should give the scene to SM. This sort of bug is hard to fix. I never see this.
If you have PP2010 I think there is a possibility the behavior may be different and worth trying. Also, you can try background and network rendering with 2010.
saibabameuk ( ) posted Mon, 11 April 2011 at 11:53 AM
Quote - You're P8 is up to date then. If you re-render an afflicted frame, is it the same? NO THE AFFLICTED FRAME AS A SINGLE RENDER IS FINE NO PROBLEM If you can reproduce this, you should give the scene to SM. This sort of bug is hard to fix. I never see this.
If you have PP2010 I think there is a possibility the behaviour may be different and worth trying. Also, you can try background and network rendering with 2010.
I notice that it happened from 130/200 frames irregular, no set pattern.
I am setting another render from 130 frames to 200 so I will report back if the same problem occurs.
RedPhantom ( ) posted Mon, 11 April 2011 at 7:59 PM
Site Admin
I've seen something like this when there was a render going with more threads than prossessors, but the holes filled when the render finished. I never saw it with an animation though. Perhaps it might be something to look at.
saibabameuk ( ) posted Thu, 14 April 2011 at 3:37 AM
Here we go ,sadly I have had a similar problem on render with PoserPro 2010, any thoughts.
I am hoping it's not my processor , using a Mac Book Pro, here are some other examples , can any one help.
saibabameuk ( ) posted Thu, 14 April 2011 at 3:39 AM
Example2
Poser Pro 2010 Mac Render Mac Book Pro
saibabameuk ( ) posted Thu, 14 April 2011 at 4:02 AM
Single Frame Render as oppose to 1/200 Poser Pro 2010- No problem!
