Forum Moderators: RedPhantom
You can also save the dynamics with a morph. At the end frame,making sure your clothing is selected under Props, select Object in the top menu, then Spawn Morph, give it a name and you will see it then in your Parameters. Move the Frame back to 01 and be sure to save the prop.
Also, save your figure pose at frame 30 or the ending frame. Then, create a new workspace, load your figure, load your prop. Pose the figure in the correct pose and change the morph setting on your cloth you saved to 1.000.
Here is what I do when I use dynamic cloth in a still image. After the simulation is done, spawn a morph target for the object, then delete the simulation and sent frames back to zero. Then I repose and set the slider for the morph target on the object to one, viola.
Regards, Michael
Hi!I have read through threads on the Cloth room- and found the clues to make my simulation work. Thanks! But how do I save it? The results are not saved with the PZ3 as far as I can tell. I hate the idea of having to recreate the final results again-if I want to render once I close the file...
I find the file ....Priest_Dress.dyn ( 9.7 mb)- how do I reload this?
PoserPro2010 Mac
