Fri, Nov 29, 6:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: 2 Part Question ~Object origin & Parameter dials
thewebflea ( ) posted Tue, 14 June 2011 at 2:47 PM · edited Fri, 29 November 2024 at 6:49 AM
Hi there to whom reads this
I have 2 Questions
1~ can i import an object into poser with its orgin set where I want or ... do i havta allways use the joint editor ?
2~ can I create parameter dials to use as ERC's
example( a louver frame with louvers )
I'd like to put the Open/Close dail in the frame parameter( Body) and hide the louver parameter (Body parts) ?
Hope i said that correctly
markschum ( ) posted Tue, 14 June 2011 at 5:19 PM
1.  No - an obj file has no specification for pivot point. The lw file format may work for setting it in lightwave but I havent tried it.
  1. Yes.  You can hide the body part dials  - hidden 1 in the file
If each louver is a seperate body part you would want erc to open them as a group.
www.atlantis23.comerc_download.html
lesbentley ( ) posted Tue, 14 June 2011 at 5:30 PM
Quote - 1~ can i import an object into poser with its orgin set where I want or ... do i havta allways use the joint editor ?
When you import an obj file you will always have to set its origin, there is no way to set the origin of an obj file. However after importing the obj it becomes a prop, if you then set its origin, then Memorize the prop and save it to a Props palette, the origin will be in the same place the next time you load the prop (pp2).
thewebflea ( ) posted Tue, 14 June 2011 at 6:06 PM
thanks for the replys
markschum - i Know how to hide the dials ... i want to hide the part parameter the from showing ... can that be done ???
lesbentley - i set the orgin in blender but when i bring it in ..... its in the center of  object..
setting it in poser can be a pain
    example if  u have 30 louvers .. all of differnt shapes ( louvers for a round Duct )  then its gonna be a lil much as we say in philly
lesbentley ( ) posted Tue, 14 June 2011 at 6:20 PM
In P6 and above you can apply a pose file to a figure to create valueParm channels in the BODY actor to serve as master channels in an ERC relationship. the format is:
version
    number 6
    createFullBodyMorph NameOfChannel
You would also need to place slaving code in the channels to slave them to the master channel. This can also be done via a a pose file. Assuming the correct channel to rotate the louvres is 'xrot', and that the louvre actors are named "Louvre_01", "Louvre_02", etc, the pose file might look like this:
version
    number 6
    createFullBodyMorph Louvres_Open-Close
actor Louvre_01
    hidden        1
    addToMenu    0
    channels
        rotateX xrot
            valueOpDeltaAdd
                Figure
                BODY
                Louvres_Open-Close
            deltaAddDelta 10.000000
actor Louvre_02
    hidden        1
    addToMenu    0
    channels
        rotateX xrot
            valueOpDeltaAdd
                Figure
                BODY
                Louvres_Open-Close
etc...
In the above example the code below is the part used to hide the actor from the menus:
    hidden        1
    addToMenu    0
The above code is meant for injection from a pose (pz2) file. If you were editing the cr2 directly in a text editor, you would use figure numbers in the slaving code, eg:
            valueOpDeltaAdd
                Figure 1
                BODY:1
                Louvres_Open-Close
You might need to adjust the value in the 'deltaAddDelta' line of the slaving code, and/or the 'trackingScale' of the valueParm channel, to get it working exactly how you want.
thewebflea ( ) posted Tue, 14 June 2011 at 7:08 PM
Thank yu very much lesbentley
Thats exactly what i was talking about
i guess i'll havta do each louver ( move origin top top like natural exhaust duct ) 1 at a time
or keep them in middle (being lazy)
unless some 1 has a better work flow
