Another option would be to save each object's motion path into the library using the create path option then saving it after the object is animated. save your objects and when you're ready for final load your paths and then situate them where you want and load and lock your objects back to them and reset the timeline the way you want.
Do atleast one thing a day that scares the hell outta ya!!
Quote - Another option would be to save each object's motion path into the library using the create path option then saving it after the object is animated. save your objects and when you're ready for final load your paths and then situate them where you want and load and lock your objects back to them and reset the timeline the way you want.
That sounds complicated :) I'll give it a try once this animation is done.
Thank you
Imagien, after so many years in Bryce and I never used the animation option before 3 days back.
clay,
You have Bryce animation instructions? Wow, that sounds useful.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Great to see folks helping each other out here!
hey clay, as the Freestuff Mod I'm compelled to ask...Ever consider uploading your animation visual instruction workbooks to Freestuff? They sound like a fabulous resource for beginners and old timers alike.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
I'making several objects that will be animated. They are going to be near eachother in the final animation.
Is it possible to save each object with the animation so I can put them together later?
It's not easy to animate every object in the same scene.
