Sat, Nov 23, 11:43 AM CST
Subject: Question for the cloth makers
Black_Star ( ) posted Sun, 03 July 2011 at 9:13 AM · edited Sat, 23 November 2024 at 11:38 AM
Hi!
I have personally tried in the past to make clothing sets, and from the whole process, what I have found the most challenging was to create the morphs for the clothing set. Do you know how can I more easily transfer morphs from V4 to my clothing set without having to manually model and then export, then import again, each morph as I am doing now.
Right now, I am modeling the morphs in 3D Studio Max, then exporting them, then importing them again intro my product's .cr2 file and so on until all the morphs are done.
This is a bothersome process, that takes a lot of time and substracts all the fun from creating a clothing set.
I have good modeling skills and I have ideeas for a lot of amazing clothing sets, but each time I end up with very simplistic clothing sets, far from what I originally intended, and that is all because of the process of creating morphs. Ah, and did I mentioned that I also have to "regroup" the model each time, before starting to even model the morph? :(
Also, if you find my modeling skills acceptable, I am open for a collaboration (I know this is not the forum for such requests, but this is only a side note to my main question above).
These two products have been modeled by me :
SteamPunk: Mechanical Doll Outfit Propschick, Black_Star
http://www.renderosity.com/mod/bcs/steampunk-mechanical-doll-outfit/81136
SFSS: A Science Fiction Swimsuit Set for V4/A4/Elite by kittystavern, Black_Star
http://www.renderosity.com/mod/bcs/sfss-a-science-fiction-swimsuit-set-for-v4-a4-elite/79871
I also have fairly good material/shading skills, visible here :
Fantasy Chronicles : Chapter I by Black_Star
http://www.renderosity.com/mod/bcs/fantasy-chronicles-chapter-i/63722
Thank you in advance!
Best regards!
markschum ( ) posted Sun, 03 July 2011 at 9:37 AM
crossdresser I believe can add morphs to clothing, and there is a product at renderosity that will also called something like morphing clothes http://www.renderosity.com/mod/bcs/morphing-clothes/64629
Lyrra had done some magnet sets to add morphs as well.
DarkEdge ( ) posted Sun, 03 July 2011 at 10:09 AM
You didn't specify but if you mean figure morphs then you want MorClothes by Dimension3D. 😄
Fugazi1968 ( ) posted Sun, 03 July 2011 at 10:59 AM
Morcloth does a good job, it's the one I use all the time.  I do fix em up in Silo though.
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
shuy ( ) posted Sun, 03 July 2011 at 5:07 PM
You can transfer morphs with poser only. Use cloth room. Select each body part of conformed cloth as constrained group and run 5 frame simulation morph 0 to 1.
vholf ( ) posted Sun, 03 July 2011 at 8:57 PM
Once upon a time there was PMorphTools, a plugin for 3ds max that greatly helped with the morphing process, sadly, it hasn't been updated for quite a while, it worked up to 3ds max 6 I believe.
http://www.3dutils.com/products/pmt.htm
On which area are you looking for colaborative help? 3ds max to Poser conversion? I could help out there. Let me know and I'll send you a site mail.
