Fri, Nov 29, 1:43 PM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Exporting BVH question
Ikyoto ( ) posted Mon, 08 November 1999 at 8:45 AM · edited Fri, 29 November 2024 at 11:46 AM
I have made a set of fighting animations - boxing, a few Wu-Shu flying dragon kicks and others. They work really well in Poser, but when I exprot them as BVH they cannot be used in Poser... Help? Even if you just tel me what page to look on it would help!
JeffH ( ) posted Mon, 08 November 1999 at 10:33 AM
What errors do you get? The bodypart names may not match. Also, Poser can't handle BVH that is much over 800 frames. -JH.
Colm_Jackson ( ) posted Mon, 08 November 1999 at 2:57 PM
Hi Ikyoto I've just tried to do what you say. I put together a simple 60 frame sequence and exported it to BVH. I then reset poser to 'New' and loaded in the same figure. I imported the BVH and it worked fine. As Jeff say's. Are the sequences too long? If you could let us know if you are doing anything differently. Colm...
Traveler ( ) posted Mon, 08 November 1999 at 5:55 PM
Coulden't you save the animation as an animated pose? Or do you want to use the .bvh with another prog? -Trav
Ikyoto ( ) posted Tue, 09 November 1999 at 2:29 PM
Trav - dead on. I've been testing Mia and it won't take the bvh from Poser... and I'll re-run the import sequence at home and post the exact error I get.
