Attached Link: jade tea cup and a candle
> Quote - Damn. RDNA lost the zip file there of my morphing glass. I'll have to make it from scratch unless somebody has it and can give it back to me. I don't really have time to build it right now.If it would be of use, the jade tea cup is half full of tea. Perhaps you could re-texture it? Or is it the original materials of your model that you wanted?
OSes: Win7Prox64, Win7Ultx64
Thanks
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Quote - > Quote - Damn. RDNA lost the zip file there of my morphing glass. I'll have to make it from scratch unless somebody has it and can give it back to me. I don't really have time to build it right now.
Is the liquid modeled as just a top surface, or an entire enclosed 3d object. That is crucial. It needs to be a closed volume with its own material, fitted precisely inside the cup or glass, or it just fails.
Sounds like it will work. The liquid is topologically closed, with a microscopic space between the inner surface of the glass and the sides/bottom of the liquid, in order to avoid having two polygons sharing the same space. The top side of the liquid has a meniscus shape.
I'm trying it. The teacup is very nice, but I'm running into the age-old glass is opaque problem. For this to work, light has to reach the liquid and it doesn't.
Wow if I didn't know better, I'd say you've been posting a photo of a cuppa milk!
I'm seeing an odd problem here and I don't know what it stems from. At first I thought it was the scene so I changed it, but the problem persists.
It's originally an old PZ3 I brought into PP2012. I guess it's from Poser 8 but it may be older, it's Simon.
I'm getting all those little light-spots all over the place.
There's no lights in the scene, the flames on the candelabras has an ambient material (15 in ambient) and so does the liquid in the bottle. Those are the only light sources in the scene.
Everything is enclosed in a room (Mother's House, I think it's from Daz)
Where do those light spots come from? Anyone got an idea, it's driving me nuts! L
Also.. Why is his nails black? Is that a side effect of the SSS (Yes I've used the wacro on all skin materials here including his nails) In the material room they're not black but normal looking :/
(Please click the pic for a proper sized version)
TG, Poser's IDL is a cheat and cannot be pushed beyond certain limits. The price we pay for speed.
You cannot use super bright small props for light. Poser does not send out enough rays to find them all from all positions, so here it hits, there it misses. You get splotchies.
Use bigger props for light sources. The new system allows us to make these invisible and keep the smaller ones to look at directly!!!
If you really want to do that sort of render, with a small 5 inch sphere lighting a large area, use LuxRender and Pose2Lux. Oh - and be prepared to render for up to 40 or 50 hours.
Thanks, BB. At the moment I'm just experimenting to see what is possible at all :)
It makes sense that the light sources are too small. Will try the InvisiLights :)
I would be very happy with a transmission color, consulted for shadow calculations. I could easily fake the caustics well enough using Edge_Blend alone. This would neatly solve the problem of avoiding unwanted shadows from glass.
I got around it here by simply reducing my main light shadow strength. But I could only do that for this isolated prop. In a general scene that would be a fail.
BB, I love that glass material! Is it one you've already published! All these renders look so cool! Unfortunately, I can't play with it yet. I opted for the physical disc of Poser Pro 2012 and I don't know how long it's going to take to get to me here in Canada. :(
Weapons of choice:
LL, no I never published that glass. I talked about it with you in a thread last year.
The last thing you said was
Quote - Ah, yes, I have that prop. I can hope that maybe SM will take consideration on the problems you've brought up when it comes to transparency and refraction. I can but hope.
I hoped so too and I was not happy with my glass. You have to be a wizard and know tricks to get it to behave. I was waiting to see if P9/PP2012 addressed the transmission color problem, the total internal reflection problem, and the inverse IOR problem.
No solutions yet.
Ummm, this is weird. Silly me, I didn't realize that the jade cup and candle zip was for Poser 9. I loaded it into Poser 8 and, um, the scatter node is there in the materials but of course not the fresnel blend node. I don't think that technically it should have loaded the material at all.
P.S. I do like the look of that glass though!
Weapons of choice:
*Transmission caustics. Is that not right? Shadow was not the correct word. This picture is what I mean so I'm clear. *
Really! Then they started work on Scatter in Poser 8 but didn't get it working right and never told us about it. Huh.
I am going to show you the new formula for Glass in P9. You will be surprised it's so nothing.
LL - do you have or plan to get P9 or PP2012?
I actually used my 44 node P8 version above, but I'm rendering the P9 version and you'll see it is the same.
Quote - you-know-who may add caustics at some point, but there may be ways to fake it that are quicker. like some things (e.g. transparency colour) are not really caustics - they work in some apps with caustics disabled.
Light passing through or not is just transmission. This is the opposite of casting a shadow - it simply not casting a shadow.
Caustics are when transmitted light beams from different places of an object are focused, creating a local hot spot that is brighter than simply transmitted light.
A caustic is not possible unless a surface is curved.
Your image shows both.
The coloring of the refraction is optional - I'm just demonstrating how to make blue glass.
The IOR being less in the Refract is intentional - a workaround for Poser's lack of inverse IOR (bending light the other way going inside to out, than the way it does going outside to in).
If you were doing single-sided thin glass, the Refract IOR should be close to 1.
In my P5 glass (used in the images before the blue one), the Fresnel_Blend node has to be implemented with many math nodes. I sometimes use an approximation, 5 nodes, and sometimes the real math, 21 (or so) nodes. I don't really know how many. I just say "TrueFresnel" in matmatic and it is done.
Quote - Your image shows both.
I know. Reflection Caustics and Transmission Caustics. I was originally refering to the missing red where the shadow lies in your render. I'm learning..
How will you produce the hot "focused" spots? *
By setting a transmission value greater than 1.
Did some tweaks and switched to tea (with milk). the tea one looks like orange juice on my screen. (good realistic OJ though)
I aim to update it about once a month. Oh, and it's free!
I sampled the tea color from a photo of tea. But it is reflecting the red glass, so it isn't just that color.
rendered in Poser 2012:
http://www.renderosity.com/mod/gallery/index.php?image_id=2249893
re-rendered in Poser 2012:
http://www.renderosity.com/mod/gallery/index.php?image_id=2226983
it used to suck having to export into high end apps just to achieve results like these. i think people take for granted how much the Firefly renderer and material room has evolved. many dont realize that just a few years ago features like indirect lighting/GI, SSS, etc were mostly found in >$5000 apps with expensive plugins. that fact that theyre all there in Poser in a beginner-friendly format and it still renders relatively fast is very impressive - hats off to the poser devs for bringing these features to the table in a 'hobbyist' app.
if youre on the fence about Poser - SSS is worth the pricetag alone.
cheers,
-Gabriel
And I've tried twice to attach this render to this post and it hasn't worked. What's up with that?
Weapons of choice:
I've got a simple thin-walled tumbler & beverage model in Poser now; I'll strip the geometries out and package it and post it shortly. This one will have the proper positive meniscus - I just realized that the ribbed tea cup beverage has a negative meniscus (ooops).
I'm confused. Why would you want a convex meniscus? Water is concave, unless it overflows the container.
Quote - I'm confused. Why would you want a convex meniscus? Water is concave, unless it overflows the container.
Yes, that has occurred to me now, and the new model will have the proper meniscus. I must have had a brain fail when I made the ribbed tea cup and tea liquid. :huh: There are combinations of liquid and container materials which have a convex meniscus, but tea/milk/beer in glass/jade ain't among them.
Render testing the new thin-walled tumbler & beverage model now, looking for any egregious errors (polys sharing same space, inverted normals, etc.)
Attached Link: thin-walled smooth tumbler with beverage
OK, I *think* I got the thin-walled smooth tumbler & beverage model attached as a zip. It is in standard format to be unzipped to your "downloads" content folder. Free for both personal and commercial renders.Nope. won't attach a zip, apparently. OK, I'll load it elsewhere and then link.
OK, got it. Use the hotlink above. :D
I always thought the surface tension of the water molecules made it slightly convex but I am probably wrong.
Love esther
Here's the prop plus the .png in a .zip file. Can't find the original .zip file so these were taken straight from my Runtime/Props directory.
Quote - I always thought the surface tension of the water molecules made it slightly convex but I am probably wrong.
Love esther
It is. Just look at a drop of water on a table or flat surface. The tension makes it convex. But if you put it into a container or glass, that same tension makes it slightly concave until it gets to the lip, just before it overflows.
yumm milk goodness. hungry for some peanutbutter cookies
wheee, next week, i renders with yoos !
iz shipping 2 day express.
yes, ppro comes in 32 as well.
