Poser 9 gets installed in Program files (x86)Smith MicroPoser 9
The essintial content gets installed there too.
But your actual content Runtime is in your Your users acount.
Search for the Actual content runtime in your users acount.
This is dictated by the OS (Vista) and how your PC is onganised.
Do a search for something simple, Ball.ppz or something alike?
Your OS should then point you to your location of Your actual content Runtime
ha-ha-, zillion Poly Vicky should be waiting for you there too.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
crz are compressed cr2
ppz are compressed pp2
pzz are compressed pz3
Poser9 will read them all
For saving yourself you can select compression ON - OFF in General preferences.
Dev
"Do not drive
There is a script included with Poser to add all your Runtimes automatically. In the top menu go to Scripts > Partners > Shaderworks > import_runtimes2012.
IMPORTANT! This script will boot you out of Poser! I would recommend shutting down any scene files before running it, if you happen to have any open.
______________
You know you have to load any external runtimes (from within poser using the add button) that you want eg your runtime with V4 in it, unless you installed V4 into your main poser runtime.
I aim to update it about once a month. Oh, and it's free!
Ok, now I'm really confused. I installed Poser 9 as recommended, using Vista-friendly installation. But I can't see any of the content libraries when I browse through the file directories. Also, how does one load up content, like V4? I used the traditional installation file for V4, and it did indeed create the data files in the runtime directories, put Poser 9 does not seem to pick it up or to recognize it. I realize this sounds weird, but I need guidance. PS: I am using Vista, with UAC enabled. PPS: please someone tell me where to find those darn files. Thanks!
