Fri, Nov 29, 1:45 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Subject: Purple Rectangles
jgmart ( ) posted Mon, 24 October 2011 at 11:56 AM · edited Fri, 29 November 2024 at 10:59 AM
Hi,
Does anyone know what these purple rectangles are?  I'm not sure if I clicked something by mistake, or something.  I have all four views set to Wireframe.  I thought changing to shaded or another type of view might get rid of them, but no.  When I first load the scene these rectagles are not there, but as soon as I move or change anything, they show up and I can't get rid of them.  It's not happening in any other scenes I have saved.
 I'm using Vue 9 Complete.
 Thanks for any info!
John
bruno021 ( ) posted Mon, 24 October 2011 at 12:26 PM · edited Mon, 24 October 2011 at 12:27 PM
Can't tell from your screengrab (too compressed, can't read your object list in the world browser). Do you have a plane that has a procedural material in the scene?
jgmart ( ) posted Mon, 24 October 2011 at 12:38 PM
Thanks for the reply!
Here's a larger object list.  It's all simple stuff, I think.  No terrains. I have two boolen cubes making an open box object, with an image for texture.  The other objects are just vobs.
Thanks
bruno021 ( ) posted Mon, 24 October 2011 at 12:59 PM · edited Mon, 24 October 2011 at 1:00 PM
Could it be one of the "basic room" object? If it's a boolean, maybe the object you used to cut the other one is using this color (either as a procedural color, or an automatic color)?
jgmart ( ) posted Mon, 24 October 2011 at 1:24 PM
I went through the objects.  As soon as I deleted the table, they went away.  I added the table back,  tried both an image and a procedural color on it, but the purble rectangle stay.  At least I know it's just the table object.  I guess I can deal with it for this sence.
Thanks for your help Bruno!
bruno021 ( ) posted Mon, 24 October 2011 at 3:52 PM
Maybe it's an automatic color Vue gave it when you loaded it. You can check that in the Apect tab of the Object manager, under the material preview.
Mazak ( ) posted Thu, 27 October 2011 at 7:24 AM
I think this is a parametric object! Some 3D applications use parametric objects (Spheres, lathe nurbs ect.) Vue can't read this objects, because they aren't made from polygons. Vue only loads this as a dummy (placeholder) object.The only solution is to bake the parametric objects in the 3D application to Polygons before import to Vue.
Mazak
Google+ Bodo Nittel
