Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Hi in the animation pallette select the frames ou wish to "lock"
and change their interpolation to constant they will turn from green or orange to white.
Cheers
Hi
I do pretty much all animations that are done in segments of anywhere from 500 to 4000 frames.
The problem I keep running into is that the first and last frames keep changing slightly.
Some times it's just the hair moving a little or the angle of the head changes just a bit.
I start each segment from the last frame of the previous segment and I have learned that if I save the frame as a pose I can usually restore it to the original setting when it gets changed but... Not always.
It would be really nice if I could lock the first and last frame of a segment to that no matter what I do tweaking the animation these two frames would never, ever change.
Then the segments would always sync no matter how much I mess around with them.
Anyone have any ideas?
Mike
If you shoot a mime, do you need a silencer?
