Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Oops. I thought you were refering to the OpenGL display of your tree colors. I do not have that tutorial to test with. I'm able to change tree color by altering overall color and/or variable color of the tree ecosystems I'm using (both painted and dynamic) so far in Vue 10 Infinite.
Happens to any trees? What kind of of eco population are you using? Painted? Absolute? Dynamic?
Absolute is when you manually click the populate button to cover a terrain with an ecosystem.
What I did was select the Color tab after loading a tree in the eco list and then put a check in the Variable color option and right-clicked the image below it to edit the function. I then deleted the color node and the other stuff linked to the Color input and added a texture map node to the Color input and loaded a color image for it.
When I populated my eco, the generated trees used the colors from the image (depending on where they were located on the terrain, which the color image was overlayed on). A lot of trees used the same color until I changed the function scale of the loaded texture map node image (from a scale of 1 to .1). Then each tree began to contain more colors from the texture map, after clearing the eco and re-populating it again.
i have always had problems using the colour option for the eco systems,no matter what colour i pick it always makes the trees look unrealistic,i wish that there was some kind of preview so you had some feedback as to what the colour will end up like
A cleaved head no longer plots.
http://www.perilous7.moonfruit.com
Quote - i wish that there was some kind of preview so you had some feedback as to what the colour will end up like
A preview in your main OpenGL window? How are you displaying plants in your OpenGL? As billboards or as something else? Or a preview in the Plant Editor?
Hi all,
I have some questions about Vue, I will start with this one:
I just started using this software, so I'm following some (old) vue tutorials. While I was following the FXPHD 201 tutorial (they use vue 8.5) , I found that the "Variable color" option (populating trees) just makes my trees all black. On the web I found that this problem started with Vue 9.
But I cannot really find a solution that works.
Thanks,
R.
