Sun, Dec 1, 11:54 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: Help with Texture problem
LuckyHolsten ( ) posted Tue, 27 December 2011 at 12:58 AM · edited Fri, 29 November 2024 at 3:39 AM
1st let me say that I'm not in any way a pro at modelling or texturing, but I'm not new to it either. However, I am new to actually sharing my stuff online.
I have pretty much everything done and ready to go, except a little problem with the the textures.
The problem is when I load the file in Daz, it cannot find the textures. I can manually set the textures in the surfaces tab, that works fine and wouldn't be a problem if I wasn't planning on sharing, but since I am going to share I want the textures to automatically load with the object.
I know this has probably been asked before and if it has I'm sorry for reposting, but I've been searching and trying to figure this out for a couple days now and haven't come up with anything.
So yeah, how can I get the textures to load automatically when I load the object?
Also, for anyone wondering. This is what I plan on sharing :D
Photobucket
Rutroe ( ) posted Wed, 28 December 2011 at 2:58 AM
Open the cr2 file and make sure the "File Path" is correct, exp: "Runtime:Textures:texturefilename:texturefile.jpg". Each plane(Surface) has a name to it, FrontPlane, BackPlane, etc. You have to manualy code it in.
Example
prop strawboaterzero:1
 material Ribbon
  {   KdColor 1 1 1 1
       KaColor 0 0 0 1
        KsColor 0 0 0 1
        TextureColor 1 1 1 1
         NsExponent 1   tMin 0   tMax 0   tExpo 0.6
         bumpStrength 1
         ksIgnoreTexture 0
         reflectThruLights 1
         reflectThruKd 0             // Below is what you may have to code in //
         textureMap":Runtime:Textures:Skip1871:SkipsFreebies:Strawboater.jpg"
         bumpMap NO_MAP      // You notice he has file within a file, this is not needed //
         reflectionMap NO_MAP
         transparencyMap NO_MAP
        ReflectionColor 1 1 1 1
         reflectionStrength 1
This is an example of what you will see
Rutroe ( ) posted Wed, 28 December 2011 at 2:59 AM
Forgot to mention, open it with notepad
LuckyHolsten ( ) posted Wed, 28 December 2011 at 3:38 AM
Attached Link: http://www.ShareCG.com/v/58236/view/11/Poser/MMA-Cage
Thanks, but I figured out a little work around and uploaded already lol
I will bookmark this though as it will come in handy with anything else I share.
Thanks again:)
