Fri, Nov 29, 12:09 PM CST
Subject: Vue File save format question
Bez ( ) posted Sun, 01 January 2012 at 8:02 AM · edited Fri, 29 November 2024 at 10:21 AM
Hi, does anybody know if it is now possible to save/export a rendered object, such as a tree, in png format with a transparent background, like you do in Poser. I know it wasn't possible in Vue 6. Or if anybody knows a way round it, I'd be glad of the info.. thanks in advance..
FrankT ( ) posted Sun, 01 January 2012 at 12:43 PM · edited Sun, 01 January 2012 at 12:50 PM
there's a tick box to include the alpha channel in PNG files - that's probably what you are looking for.  It's under the "options" button when you save the render. or there's an option on the rendered image too looks like a square with a circle in it.
Happy new year btw :)
(this is in Vue 8.4 infinite)
See piccie
My Freebies
Buy stuff on RedBubble
blaineak ( ) posted Sun, 01 January 2012 at 2:04 PM
First select the object you want from your scene, any object or objects and then go to "Render Options". You will see a drop down on the left side towards the bottom titled "Render What". Choose "only selected objects", then do as FrankT pointed out above. That gives you only the object and a transparent background.
Bez ( ) posted Sun, 01 January 2012 at 2:18 PM
Thanks to both of you for the info and thanks Frank for the pic. I will consider upgrading to the latest version now that I know it's possible.. Happy New Year to you all and thanks again :)
gillbrooks ( ) posted Sun, 01 January 2012 at 5:04 PM
Bez, if you want somehting before you upgrade, I have an old but quite detailed tutorial on how to do it here
http://www.gillsplace.com/press/category/vue/tutorials/
Gill
Bez ( ) posted Mon, 02 January 2012 at 5:51 AM
Thanks Gill, I thnk I tried that a couple of years back, although it won't hurt to give it another try.. thanks again :)
