Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Which catsuit? P4 or Vicki? V2P4 would use P4. The hands and feet of V2P4 are Vicki - unaltered. I am unsure, but the Forearm may be also. If you are using a P4 catsuit this would probably cause JP problems. Because V2P4 is a hybrid, you may be pushing the limits. It may be better if you could do the character as Vicki instead and use her catsuit. I expect the feet to give a problem also.
Attached Link: http://jvipond.tripod.com/spectrum/
I decided to try basing the Easy Breather on the Vicki2P4 figure, which is essentially Victoria 2 modified to wear clothes designed for Posette. My rationale is that Vicki2P4's CheekBalloon morph target, not innate to Posette, is useful for super breath effects. After shaping the face of the nude Vicki2P4, spawning a "Samantha" morph target for the head and setting all but my custom morph to zero, I ran Samantha (my modified Vicki2P4) through Poser Maconstructor and removed all the morphs I did not plan to use on her. Wearing only her blond hair, she is a trim 5.4MB, compared to the 13.3MB of the full Vicki2P4. When Samantha is in the default pose (standing upright, arms perpendicular to body), I can make John Stroo's footed catsuit fit her by applying a chest magnet and scaling various parts of the catsuit. When I bend her arms, however, the catsuit sleeves fail to conform (see image), but the rest of the garment fits. Quite embarrassing for a crimefighter! This does not seem to happen with any other female garments. Any advice on fixing the sleeve problem would be appreciated.
