Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 6:46 am)
The fingers look a bit long. The chest looks rather strange to me. I looks more like he has small female breasts than male pectoralis. The neck looks too long, and the muscle mass to the side of the neck (trapezius?) looks to big in comparison to the rest of his physique.
Sorry if all this sounds a bit negative, but thought it best to be honest. I wish you success with your project.
Yep, it's a WIP
Thanks for the sugestions guys.
There is also a problem around the eyes I still have to fix.
**Be as critical as you can.
**Remember , it is a morph, and slight re-rig of the chap in the background.
Simple Poser9 test render, no SSS yet, nothing..
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
There's something with the head, neck and shoulders. The head almost looks too small for the neck and shoulders. The neck is a bit short and thick. I know you're going for musuclar definition on the shoulders but the center figure with his arms down looks like he's got two humps stuck on the top his shoulders.
Hips too large, rib cage too small around shoulders. Nipples should be more "outboard", with a stronger line separating chest from abdomen.
Overall, very soft looking. No indication of underlying bone or muscle (iliac crest, rib cage, serratus, abs). This looks like a lo res mesh, so not sure how much detail it can support. Highly recommend ZBrush Digital Scultping Human Anatomy. Even if not using the program, is really insightful.
Thank you all for the constructive comments.
It is a morph for the PoserPro Lo res male with just under 8.000 Poly's that is standing in the background.
He is included in the image to give a "From=> To" impression.
As it is a morph, I can not add Poly's, only work with the existing ones.
Just trying to make the most of the existing 8000 Poly mesh.
Will continue work tonight and post an updated image.
Target?
To do "more" with "less".
Dev
"Do not drive
Attached Link: http://poser.smithmicro.com/tutorials/Characters_model_import.html
> Quote - You're version is definitely an improvement over the original--I wish SM could have given a better defined body for people to work with--it's kind of like shaping clay isn't it?
Not a huge fan of those figures myself wish I was modeling for SM at that time but I was in tech support.
If looking for a slightly better looking low res male you could try this one that we gave away in a tutorial. In hindsight, there's a lot I'd do different on that mesh but ya know...whatever.
Apart from the above comments - I particularly agree with the Odo comparison - they look like they bend like glass.
ha-ha-ha-
if I only knew who this Odo character was..............
but work will go on tomorrow :-)
Anyone wants to see the "she" part?
For the PoserPro Lo res female?
Also a WIP but allmost completely finished in multiple versons :-)
Dev
"Do not drive
Morphed + a little rigging and texture work (but still the origional texture)
Dev
"Do not drive
Click to enlarge. OK, let's have your comments.Poser 1, 2, 3, 4, 5, 7, P8 and PPro2010, P9 and PP2012, P10 and PP2014 Game Dev
