Thu, Feb 27, 6:25 AM CST
Subject: Bryce 7 Installation problem
Jack Casement ( ) posted Sat, 07 April 2012 at 7:06 AM · edited Thu, 27 February 2025 at 6:10 AM
I have just got a new computer and have tried to install Bryce 7 but I get this error report
"This programme has failed to start because it's side by side configuration is incorrecr"
Any ideas please? It worked perfectly on my old computer
Cheers
dan whiteside ( ) posted Sat, 07 April 2012 at 7:12 AM
Attached Link: Side by side error
Check out this thread for install fixes.
Jack Casement ( ) posted Sat, 07 April 2012 at 7:37 AM
Dan thank you so much.  The error message has gone but it is now asking for the serial number.  But this was a free programme so where do I find it?  Cheers.  Jack
Ravyns ( ) posted Sat, 07 April 2012 at 8:01 AM
The serial should be under Available Serial Numbers in your DAZ account.
Life may not be the party we hoped for but while we're here we should dance.
bobbystahr ( ) posted Sat, 07 April 2012 at 8:14 AM
Yup that's where it should be...just had to do that myself yesterday as I'd forgotten to reinstall Bryce after my HDD makeover
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
Jack Casement ( ) posted Sat, 07 April 2012 at 8:17 AM
Thank you ravyns.  Found it.  Done it.  It works
rstar ( ) posted Thu, 17 May 2012 at 7:56 PM
Quote - Check out this thread for install fixes.
I had to reinstall my OS and now I get the same "side by side error". When I click the link you supplied, I get a 404 error and am dead in the water.
Can you please give it out again so I can get to it to fix my Bryce installation problem?
rstar
Ravyns ( ) posted Thu, 17 May 2012 at 8:33 PM
I'd guess that the error you're getting has to do with DAZ redoing their website. I read somewhere that they aren't moving the forum content to the new site. Don't know if it's true or not.
rstar ( ) posted Fri, 18 May 2012 at 3:53 AM
I had the same suspicion. Seems like we get usd to a process and then they change it for the "better" but then it isn't quite as user-friendly as we were used to.
I figured it out though, as I had saved tha data from the last time we went through this.
Thanks Ravyns, I appreciate your quick response.
This is still the best community going for the beginner and the non-proffessional!
Gremalkyn ( ) posted Fri, 15 June 2012 at 10:04 AM
At the risk of being a hijacker, I have a different install warning:  "Bryce 7.(whatever the free version from Daz is) is not a valid Win32 operation and may damage your computer."
I am running Windows 7 64 bit and presently have this thing sitting in My Downloads.  Should I delete it and buy a more compatable version later?
bobbystahr ( ) posted Fri, 15 June 2012 at 9:41 PM
been no reports of that here so far...maybe hop oner to the DAZ3D forum and see if it's been reported as a bug or something...
I see a sound
stillhawk ( ) posted Sun, 17 June 2012 at 4:29 PM
Quote - I have just got a new computer and have tried to install Bryce 7 but I get this error report
Cheers
I have the same problem but the link suggested by dan whiteside isn't working. Can anyone actually enter the solution rather than a link.
Thanks so much.
stillhawk ( ) posted Sun, 17 June 2012 at 5:55 PM
Quote - > Quote - I have just got a new computer and have tried to install Bryce 7 but I get this error report
Cheers
Thanks so much.
I discovered the problem. Something was amiss with my C++ (.86).
Use the following link to Microsoft.
http://www.microsoft.com/en-us/download/details.aspx?displaylang=en&id=26347
Download and run vcredist_x86.EXE
Oh. and here is the Bryce 7 Pro serial number you need:
**BDZCPRO-070-0287868-WST-001-OBVAMHI
Hope this helps others.
mikedaddysmooth ( ) posted Mon, 09 July 2012 at 2:00 AM · edited Mon, 09 July 2012 at 2:01 AM
Me too on this prob.
I tried the download from Microsoft, didn't work, any other ideas?
You should never doubt what no one is even sure about.
http://www.mikedaddysmooth.com
stillhawk ( ) posted Mon, 09 July 2012 at 8:48 AM
You might try the suggestions provided by The Ohio State University at the following link:
http://8help.osu.edu/4303.html
Good luck.
mikedaddysmooth ( ) posted Mon, 09 July 2012 at 11:21 PM
Ok People, once apon a time I had this problem, searched the archives and Marfornohelped, and  it still worksnothing above worked, this did.
Go here:
https://helpdaz.zendesk.com/entries/20633961-side-by-side-configuration-in-bryce-7
Scroll down to the first download, works wonders.
File this one away.
