I'd guess that the error you're getting has to do with DAZ redoing their website. I read somewhere that they aren't moving the forum content to the new site. Don't know if it's true or not.
Life may not be the party we hoped for but while we're here we should dance.
I had the same suspicion. Seems like we get usd to a process and then they change it for the "better" but then it isn't quite as user-friendly as we were used to.
I figured it out though, as I had saved tha data from the last time we went through this.
Thanks Ravyns, I appreciate your quick response.
This is still the best community going for the beginner and the non-proffessional!
At the risk of being a hijacker, I have a different install warning: "Bryce 7.(whatever the free version from Daz is) is not a valid Win32 operation and may damage your computer."
I am running Windows 7 64 bit and presently have this thing sitting in My Downloads. Should I delete it and buy a more compatable version later?
Quote - I have just got a new computer and have tried to install Bryce 7 but I get this error report
"This programme has failed to start because it's side by side configuration is incorrecr"
Any ideas please? It worked perfectly on my old computer
Cheers
I have the same problem but the link suggested by dan whiteside isn't working. Can anyone actually enter the solution rather than a link.
Thanks so much.
Quote - > Quote - I have just got a new computer and have tried to install Bryce 7 but I get this error report
Cheers
Thanks so much.
I discovered the problem. Something was amiss with my C++ (.86).
Use the following link to Microsoft.
http://www.microsoft.com/en-us/download/details.aspx?displaylang=en&id=26347
Download and run vcredist_x86.EXE
Oh. and here is the Bryce 7 Pro serial number you need:
**BDZCPRO-070-0287868-WST-001-OBVAMHI
Hope this helps others.
Me too on this prob.
I tried the download from Microsoft, didn't work, any other ideas?
You should never doubt what no one is even sure about.
http://www.mikedaddysmooth.com
Ok People, once apon a time I had this problem, searched the archives and Marfornohelped, and it still worksnothing above worked, this did.
Go here:
https://helpdaz.zendesk.com/entries/20633961-side-by-side-configuration-in-bryce-7
Scroll down to the first download, works wonders.
File this one away.
Cheers
