Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
the point is of course to fade the character, not the reflectivity of the mirror: when the char fades in the mirror it reflects more of the environment.
personally I'm a "never do in 3D what can be done in 2D" person, so my initial idea would be to render twice; visible to raytracing ON and OFF, and merge them at will by overlaying both layers in the video editor. This way I can alter the fading speed / moments without any re-rendering and almost interactively. I can even make the character and its clothes fade at different rates (3 re-renders), and so on.
Any Poser scheme seems quite elaborate to me, require a lot of testing / re-rendering, etcetera. We'll see if anyone comes up with something.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Thatnk you yeah I might have to go the 2d route with my renders. Benice if they had a way to adjust via a dial that turn off in raytracing setting. :)
You know you enjoy 3D Art when you realize that your life is a piece of 3D Art. :)
AMD 7900X3D, 64 GB Corsair Vengeance DDR5 Ram, Asus Prime X670-P Wifi MB, PNY RTX 4070Ti Super 16GB, 14TB SSD's & HDD, Windows 11, Poser 9 / Pro 2012 / Pro 2014, Daz Studio 4.22.
It would be fairly simple if there was a way to animate material settings (like transparency), but I don't know how to do that. If anyone knows how, please post it. It could be very useful.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
Thanks wimvdb, that is great information. I think I'll go play with it.
Poser Pro 2012 SR3
24G RAM
@wimvdb: yeah that was the one. Depends on the poser version (you need P9/Pro2012). Re-rendering when playing with the fading speed might not be an issue, but might when it's large size / high quality and you're interactively discussing things with a client or so.
@wimvdb thank you for the info will try that see what it happens. :)
Hi I am wondering if it is possible to have an objects reflection fade in a mirror but still be visible to the camera. Basically having someone slowly become a vampire and they see their reflection slowy fade in the mirror.
I know how to do the invisible in mirror by turning off object in raytracing, but is it possible to do this without having to do multiple frames? Or is it a case of rendering the first frame as normal and last frame after the change as normal and then use the transperancy section in the material room and fade them out that way.
Any help would be greatly apprieciated thank you. :)
