Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
From the instructions:-
Over 70 control cages are included with the program. This should cover the bulk of the most popular figures. If you find that your figure is not supported you have these options:-
Cages should be symmetrical
Very little finesse is required it does not need to be exact. You could make one for just the front of the face with a few more or a few less vertices. Just be sure to follow the naming convention. For Ryan that will be P8Ryan_HR-CAGE.obj and for Ryan2 that will be Ryan2_HR-CAGE.obj .
Please let me know if you get stuck but it should only take you a couple of moments.
Cool! that means I can make my own, so I only have to match the Figures obj name with the cages name and put it on the folder where the other cages are?
This should be easy, thanks for the responce!
is there a control cage for Ryan? it says he is not supported figure
Also is there a way to create a cage for him using the available ones?
My FreeStuff
