Wed, Feb 26, 8:30 PM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 25 7:07 am)
Subject: Question about DS4.5 and Previous Installs
animajikgraphics ( ) posted Fri, 05 October 2012 at 11:50 AM · edited Wed, 26 February 2025 at 8:21 PM
I'm really thinking seriously about installing DS4.5 on my machine, but have a  question before I go ahead.
While I'm sure installing 4.5 will over-write my existing 4.0 version (not so concerned about that), but will it affect my DS3A version I have installed on the same machine?
I still use DS3A a lot and don't want to loose it's functionally.  Right now I am able to use either 3 or 4 on my machine, but newer Genesis content at Daz seems to be coming out in the 4.5 (.duf) format.  I heard good things about speed improvements and stability issues, but don't want to mess up my DS3A install.
I am on a Mac running OS X .7 (Lion) if that matters.
I'd love to hear from people with a similar setup if possible.
Appreciate any tips, thoughts, suggestions...
-AniMajik
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
marciushess ( ) posted Fri, 05 October 2012 at 12:00 PM · edited Fri, 05 October 2012 at 12:00 PM
There is no problem installing 3.0 and 4.5 together. One doesn't affect the other and they work separately, sharing the content you already have without incompatibility issues.
animajikgraphics ( ) posted Fri, 05 October 2012 at 12:05 PM
Thanks marciushess, that puts my mind at ease!
-AniMajik
marciushess ( ) posted Fri, 05 October 2012 at 12:44 PM
You welcome.
vitachick ( ) posted Fri, 05 October 2012 at 1:15 PM
Well on my win7 machine I "uninstalled Daz 4.5"...Daz4 worked perfect but the format was changed...Personally I do not recommend it. My WinXP mach both Daz3 and 4.5 run perfect....
Win10  Poser 2014/Poser 11 Daz3D
animajikgraphics ( ) posted Fri, 05 October 2012 at 1:25 PM
Quote - Well on my win7 machine I "uninstalled Daz 4.5"...Daz4 worked perfect but the format was changed...Personally I do not recommend it. My WinXP mach both Daz3 and 4.5 run perfect....
What are the issues with the format that you had?  I assume you're talking about the new .duf format?
-AniMajik
marciushess ( ) posted Fri, 05 October 2012 at 1:26 PM
Depends on a lot of things of course.  In my experience that's no problem, I use both, 4.5 and 3.0 with Win7 Ultimate for a long time without problems. But, as a said, depends on a lot of factors. At first sight there's no problem.
marciushess ( ) posted Fri, 05 October 2012 at 1:30 PM
Anyway, if you install both and have any problem, you can unistall one without damage the other. Actually DS 4.5 is a lot better than 3.0. 'Course that a lot of things to fix and improve, but without any doubt is much better than the old version. So if I have to choose one, would be 4.5 without question.
vitachick ( ) posted Fri, 05 October 2012 at 1:34 PM
Quote - > Quote - Well on my win7 machine I "uninstalled Daz 4.5"...Daz4 worked perfect but the format was changed...Personally I do not recommend it. My WinXP mach both Daz3 and 4.5 run perfect....
-AniMajik
I was saving characters, scenes to my desktop, where I have a work in progress folder.  When I went to reopen kept getting errors cannot locate certain files. I was advised to move my content folder someplace else and list location in preferf. I did and same problem. Wasn't worth the aggravation so I uninstalled..
animajikgraphics ( ) posted Fri, 05 October 2012 at 1:44 PM · edited Fri, 05 October 2012 at 1:45 PM
I don't have any problems with 4.0 and 3.0 - in fact I have actually rendered using both at the same time on one machine.  My main concern was the new version would affect 3.0A (which you clarified for me)
-AniMajik
animajikgraphics ( ) posted Fri, 05 October 2012 at 1:52 PM
Quote - > Quote - > Quote - Well on my win7 machine I "uninstalled Daz 4.5"...Daz4 worked perfect but the format was changed...Personally I do not recommend it. My WinXP mach both Daz3 and 4.5 run perfect....
-AniMajik
That is a pain! I can understand why you did.
I'm going to do a lot of tests first before I use it in production.  I mainly do animation (image seqs) rather than stills. I also re-open the same scene files frequently and that could be a major issue for me.  Thanks for the heads-up!
-AniMajik
marciushess ( ) posted Fri, 05 October 2012 at 2:38 PM
The onlu problem that se, is the scenes saved in DS4.5 cannot open on 3.0, but scenes saved on 3.0 you can open on 4.5 without problem.
vitachick ( ) posted Fri, 05 October 2012 at 3:36 PM
Something was wrong as I couldnt even open my saved Daz3 files completely.
marciushess ( ) posted Fri, 05 October 2012 at 4:22 PM
DS save the scenes based where the files are at that moment. So if some file isn't in the same place where saved before, DS won't open it.
vitachick ( ) posted Fri, 05 October 2012 at 4:55 PM
I just gave up..All my existing saved scenes/characters/props just wouldn't open properly. After Deleting 4.5 everything worked....Not important..Done deal and I'm happy...I still have 4.5 installed on my WinXP32 bit mach..
JQP ( ) posted Sun, 14 October 2012 at 12:12 PM
DS 4.5 is a big fat pile of crap. I just had to come over here and say that, because being a DAZ corporate forum, I have no idea how censorious they will become over me taking a dump on it.
But that's what it deserves.  It's a four-flusher.  They not only didn't fix the Property Editor - they made it worse!  I didn't think that was possible, but they did.  It used to be buggy and crash DS on a CONSTANT (by that I mean, CONSTANT) basis, but at least it saved properly.  With 4.5 I'm finding that after a crash, my previous save didn't take.
Basically, software for Sisyphus.
I had the problems loading saves mentioned by others, too.  Then there's the fact that DS's ballyhooed "tiny saves" are actually twice the size of the old saves.
The only improvement I can find is that the speed and smoothness of auto-fit and smoothing groups have been improved, and morphs are indeed retained after auto-fit.
The supposed faster viewport speed never showed up.  Numerous new problems did, however.
No thanks.  I usually don't get into these rants over software, finding the truth to be somewhere between the naysayers and the boosters, but this one's just crap AFAIC.
Uninstalling now and reinstalling 4.0.3.9, with fingers crossed.
vitachick ( ) posted Sun, 14 October 2012 at 12:59 PM
Wow..Least someone agrees with me....Thanks guy!!
animajikgraphics ( ) posted Sun, 14 October 2012 at 6:39 PM
Well, I went ahead and installed it on one of my machines. (I have 3.0A and 4.0Pro  on my 2nd machine anyway as a fall-back)
The install of 4.5 went fairly smoothly, and I don't experience any of the issues @vitachick and @JQP seemed to have, but to be fair, I haven't had time to put it through all the paces.
It does save a lot quicker, and I had no problem opening a saved file from my desktop. (I'm on a Mac, so maybe the save/load works better on my platform in this version? - I don't know?)
I don't think this update was for bug fixes, it was so the new poser importer would be compatible.  They're hoping to expand Genesis to the Poser market.  All the new figures for Genesis seem to be coming out in that format now.
I'm hoping ( big :) ) some of those bug fixes you guys are experiencing will be forthcoming soon (not Daz soon!)
The install didn't touch my 3.0A install on that computer and I'm glad of that, since I use that 99% of the time for animation on both computers.
Thanks for all the input and advice guys!
-AniMajik
JQP ( ) posted Mon, 15 October 2012 at 6:06 AM · edited Mon, 15 October 2012 at 6:08 AM
I really really wanted to like 4.5 and have it work for me.  4.0.3.9 has a lot of warts.  But 4.5 just isn't ready.
Another annoyance, I just saw on another thread how if you have saves with figures with visibility turned off, you can't turn it back on if you load them in 4.5.  Well, saving with invisible figures is standard practice for me.  I was wondering what was up with that.  I like to put multiple hairs on figures, drop them into a null, and turn their visibility off.  Clothes too.
Really, the problem is that we can't install multiple versions of DS (except in an unsupported way, by having a 32-bit version of one release, and a 64-bit version of another).  It's really a bad combination, what with DS not having any documentation, and with DAZ going with the "rapid dev" model and playing it pretty fast and loose with the updates and quality control.
I guess I'm going to have to wait at least until 4.5 is out of beta (maybe I should wait for "gamma" or something, because DAZ's betas feel like pre-alphas to me.
vitachick ( ) posted Mon, 15 October 2012 at 7:10 AM
One thing I don't like about Daz is not being able to render on screen. Render in another window but the exsisting window doesnt change..What good is that?  I still torture myself but prefer Daz3. Simple no problems..Don't understand the new format either...Why not just have everything go to Daz/Studio/Content...(Daz3 or Daz4 folder) Simple??? Now in order to get Dson Importer you have to have 4.5...
arrow1 ( ) posted Tue, 16 October 2012 at 5:02 PM
One thing I found about 4.5 is the 3d Bridge only works with Adobe Photoshop Extended 6.Since I have a nearly $3000 investment in Adobe CS4 Creative production suite I do not have the funds to upgrade.(Another $1500) At least I thought it would be compatible with the CS4 suite like the previous version.I have gone back to 4.03 because of this reason. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
animajikgraphics ( ) posted Tue, 16 October 2012 at 5:38 PM · edited Tue, 16 October 2012 at 5:39 PM
I use Adobe Production Suite 3 and 5.5 (separate installs on each on my machines). I don't use the 3D Bride anyway, so not an issue with me. I mostly inport into AE.
I hear you about the amount $$ that you have to lay out for these, but they are essential. And it's not just the apps themselves, but all the plugin you usually have upgrade as well! (I have a lot of those for PS and AE)
Sometimes it's not always best to install the latest, greatest version. If you have a workflow that works, stick with it!  I only wanted 4.5 because all of the newer models are in the DSON format (mostly the 3DU and Smay Genesis toons).  I know that Daz has the new DSON importer for Poser, but I dread the thought of going back to Poser again!
At least I still have DS3A to fall back on until Daz works out the quirks.
