Sat, Nov 30, 1:26 PM CST
Subject: how can I chage the lighting in the face sculpting area?
256 ( ) posted Mon, 05 November 2012 at 7:01 PM · edited Sat, 30 November 2024 at 1:17 PM
How can I change the lighting on the head in the face sculpting area? I am using poser 7.
It looks horrible and blasted to bright and makes head look flat so it is hard to see good results when using  the face shaping tool.
thanks
NanetteTredoux ( ) posted Wed, 07 November 2012 at 7:24 AM
Are you referring to the face preview in the face room?
Poser 11 Pro, Windows 10
256 ( ) posted Wed, 07 November 2012 at 12:02 PM
yes
vilters ( ) posted Wed, 07 November 2012 at 1:14 PM
Load a high resolution texture instead of the default one.
Button on the lower part of the sceen?
FrankT ( ) posted Wed, 07 November 2012 at 1:24 PM
Quote - Load a high resolution texture instead of the default one.
how is that going to help with the lighting ?
My Freebies
Buy stuff on RedBubble
vilters ( ) posted Wed, 07 November 2012 at 1:45 PM
It does not change the light, but you can control is a bit by darkening the skin you want to load.
Or play with the skin darkness you load.
Preview in the faceroom is only 512x512, so you will NOT see the details.
And max texture for loading is 4096x4096 => (But will be previewed ad 512x512)
Make a copy of the head texure, resize to 512x512, and darken it a bit.
NanetteTredoux ( ) posted Wed, 07 November 2012 at 2:01 PM
Vilters's solution is the best available - you can't actually change the lighting in the face room preview, as far as I know.
256 ( ) posted Thu, 08 November 2012 at 3:14 AM
ok..I was hoping to change lighting. I would think they would want that in future versions.  I would think that would be usefull. Anyway...The head I am making is solid color no texture. A light gray. I was hoping the shadow or lighting would allow me to focus on the characters shape without distraction of texture. thanks
