Wed, Feb 26, 7:19 PM CST
Forum Moderators: RedPhantom
Subject: A figure into a wireframe
Jack Casement ( ) posted Thu, 15 November 2012 at 8:02 AM · edited Wed, 26 February 2025 at 7:16 PM
As a real beginners with Poser 9, is there a way to turn a human figure (or any figure) into a wireframe?
Many thanks
Jack Casement
lowpoly ( ) posted Thu, 15 November 2012 at 8:07 AM
select figure and press alt+ctrl+3
EnglishBob ( ) posted Thu, 15 November 2012 at 8:23 AM
If you mean to render as a wireframe, select the wireframe option you want to display (such as in lowpoly's example). Note that you can choose to have the whole scene displayed in wireframe, which will probably be visually confusing, or only a selected figure or prop. Then choose anti-alias from the render menu - don't actually render.
If you want to render larger than the preview window, then make a "movie" with only a single frame, and choose the appropriate settings.
I can only be vague about the exact procedure since I'm currently teetering on the brink of buying Poser 9. However it can be done in earlier versions and I'm sure the ability hasn't been taken out.
Sa_raneth ( ) posted Thu, 15 November 2012 at 9:12 AM
P 9 is on sale  till tomorrow EnglishBob
Jack Casement ( ) posted Thu, 15 November 2012 at 9:36 AM
Many thanks everyone for your help
Teyon ( ) posted Thu, 15 November 2012 at 9:50 AM
You can also load the texture template for the character or prop as an actual texture and render that.
bobbesch ( ) posted Fri, 16 November 2012 at 4:56 AM
> Quote - You can also load the texture template for the character or prop as an actual texture and render that.
This is Victoria 3 with this method.
bagoas ( ) posted Fri, 16 November 2012 at 2:25 PM · edited Fri, 16 November 2012 at 2:26 PM
And if you invert the image (white mesh on black) and plug it into a transparency channel, you get an actual wireframe.
primorge ( ) posted Sat, 17 November 2012 at 6:08 AM
I often increase the ambient value on the figure and in smooth shaded lined style do a preview render... I've found that it gives a very detailed and clear image of the mesh.
Jack Casement ( ) posted Sat, 17 November 2012 at 11:18 AM
Thank you all for the terrific examples.  I just think they are a bit beyond me
primorge ( ) posted Sat, 17 November 2012 at 4:55 PM
Here's one of my wire frame methods...
primorge ( ) posted Sat, 17 November 2012 at 4:56 PM
primorge ( ) posted Sat, 17 November 2012 at 4:57 PM · edited Sat, 17 November 2012 at 5:00 PM
primorge ( ) posted Sat, 17 November 2012 at 5:04 PM
primorge ( ) posted Sat, 17 November 2012 at 5:05 PM
primorge ( ) posted Sat, 17 November 2012 at 5:06 PM
primorge ( ) posted Sat, 17 November 2012 at 5:07 PM
primorge ( ) posted Sat, 17 November 2012 at 5:11 PM
...you can experiment with the various settings like color in ambient color, also you may have to disable transparency in the lashes or hair or cornea in the material room if you like.
Jack Casement ( ) posted Sun, 18 November 2012 at 3:11 AM
Thanks Primorge, you make it look so easy.  Will give it a try.  Cheers
moogal ( ) posted Mon, 19 November 2012 at 6:09 PM
Quote - > Quote - You can also load the texture template for the character or prop as an actual texture and render that.
Loading any .obj into free UVMapper will let you produce such a template (as a b/w wireframe).  Making this into a negative and adding it to your transparency channel would produce a nice wireframe look.  With backsided polys removed it would probably look like a holgraphic projection of some kind.
