Thu, Feb 27, 9:42 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 8:38 am)
Subject: Cloth Room help
charlie43 ( ) posted Sat, 17 November 2012 at 11:56 AM · edited Tue, 11 February 2025 at 11:19 AM
Hi, Gang~
Having some real issues in the cloth room. As you can see in the image, the mesh is broken and scrunched up so badly it is unacceptable. I am using PP2010. I leave most settings at default when in the cloth room. I DO check cloth self-collision. This dress is one I have created in Blender, following instructions from a tutorial by Lady Little Fox at RDNA. She is a superb modeler, and her tutorial is excellent. Subdivided, there are 67,162 faces, so I feel that there is sufficient polys for it to play nicely in the cloth room. This is an ongoing problem for just about everything I model, and it is giving me fits. I am sure that a more experienced modeler than I am can tell me what I am doing wrong. Any help much appreciated...
Peace,
Charlie~
paganeagle2001 ( ) posted Sat, 17 November 2012 at 11:59 AM
How many frames?
Did you do a drape before the sim, if so how many drape frames?
All the best.
LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
charlie43 ( ) posted Sat, 17 November 2012 at 12:56 PM
@paganeagle2001 - 30 frames. Started at frame 1 w/ the standard T pose. At frame 15 I posed V4 in the walking pose from general poses for V4. I did not do a drape before the sim.
Thanks,
C~
paganeagle2001 ( ) posted Sat, 17 November 2012 at 1:28 PM
I normally go at frame 20 for the pose.
Try with between 5 and 10 for the drape to start with.
Switch on cloth colission.
When doing the Clothify, try a different seeting than the usual 1.00 for the Collision Offset. Try .75 or .50.
All the best.
LROG
RedPhantom ( ) posted Sat, 17 November 2012 at 4:02 PM
Site Admin
That spot under the arm looks like the upper arm is intersecting the body.
vilters ( ) posted Sat, 17 November 2012 at 4:48 PM
Everything needs room and space.
Try to put 2 gallon in a one gallon bucket.
If the vertex have no room to go into???? This is what one gets?
67.000 + faces??? Hello, goodmorning.
Secondly?
I have seen this happening with other "oversize" clothing.
Closer fitting clothing usually works better.
Third?
Are there groups???? Welded groups??
Dynamic works best with one single group.
Last:
Check and X-check that there is NO intersection of the cloth and the figure at frame 1.
LaurieA ( ) posted Sat, 17 November 2012 at 6:31 PM · edited Sat, 17 November 2012 at 6:35 PM
Oh, and what of the resolution? I can see by the size of the spikes there at the shoulder the res is fairly low. And they're right about the armpit. Dynamic cloth doesn't like to be pinched.
One more thing...and don't feel bad because EVERYONE does this....but 30 frames isn't enough for a good drape. You need more. More frames for the fabric to decide where it wants to go. I normally run 100 and put the pose at 75. It has 75 frames to decide where to go.
Your fold resistance also looks like it might be high. Turn it to 1.0 or 1.5 and see what happens. Parts that are folding need to, well, fold. LOL.
Edit: I reread your post and it looks like you have more than enough mesh. If you leave the defaults that's no good. The default cloth density is really pretty stiff. Try doubling it. Also, you don't really need cloth self collision unless you have a layer of cloth touching another layer. Turn that off. I never, EVER leave the cloth settings at the default unless I wanna drape a piece of burlap :P.
charlie43 ( ) posted Sat, 17 November 2012 at 7:59 PM · edited Sat, 17 November 2012 at 8:00 PM
@vilters - I thought that number extremely high, also. I exported the un-subdiveded mesh and brought it back in w/o V4. How does 288 faces sound to you? Presumedly, Blender was counting all faces in the scene, which included V4. The clothing fits her very closely. It is one of the things LLF taught me. It surely does not appear so in the render from the cloth room. Back to the drawing board...
@LaurieA - thanks for the tips. I am going by a tutorial by Propschick or Biscuits - can't remember which. I will use your settings. You are getting to be my go-to girl, young lady. Many thanks...
C~
3anson ( ) posted Sun, 18 November 2012 at 2:04 AM
288 faces?  if that equates to polys , the dress is way too low in resolution.
you need at least a few thousand polys ( 8 to 10 for a dress) for it to look anything like
good.
grab one of the freebies here and look at the poly count in Blender.
the way the mesh 'flows' can also make a big difference in how it drapes as well;
if you can approximate the way the polys flow to a similar way as the figure itself, the drape will be smoother.
vilters ( ) posted Sun, 18 November 2012 at 2:25 AM
Yes at 288, I agree that is on the extremely Low Poly count side.
Time for a wireframe view.
For best calculations, the clothing mesh should have the +/- the same poly density as the underlying figure.
A few 1.000 for a Jacket.
show a wireframe.
3anson ( ) posted Sun, 18 November 2012 at 2:34 AM
couple examples, long dress is approx 15000 polys, sweater is about 20000 polys
LaurieA ( ) posted Sun, 18 November 2012 at 8:38 AM · edited Sun, 18 November 2012 at 8:39 AM
Yanno, I could have sworn the OP said the item was 67,162 faces. If it IS only 288 faces than I stick with my first assessment....way too low. Subdivide that at least once or until you get about 10-15 THOUSAND. LOL
paganeagle2001 ( ) posted Sun, 18 November 2012 at 9:31 AM
Agree, do a single subdiv, export it and test.
If no improvement, do another subdiv on the original mesh (that would be 2 subdivs at the moment), export and test.
Keep upping the subdiv by another one each time until you get the effect you need.
All the best.
LROG
paganeagle2001 ( ) posted Sun, 18 November 2012 at 9:42 AM
A quick example. A low poly dress on V4 - no subdiv at the moment.
I'm using Silo 2.2 Professional
All the ebst.
LROG
paganeagle2001 ( ) posted Sun, 18 November 2012 at 9:43 AM
Now I use a single Subdiv and a Refine Mesh.
See how the mesh now has more polys to play with.
Could still be a bit on the low side.
All the best.
LROG
paganeagle2001 ( ) posted Sun, 18 November 2012 at 9:45 AM
Now another Sibdiv and Refine Mesh, so that's just 2 subdivs.
As you can see, again the poly count has gone up.
The more polys you have to work with, the better the drape in the cloth room.
All the best.
LROG
paganeagle2001 ( ) posted Sun, 18 November 2012 at 10:16 AM · edited Sun, 18 November 2012 at 10:17 AM
Dress exported and sim done. I took off a few polys near the bottom to make a shorter dress.
All the best.
LROG
charlie43 ( ) posted Sun, 18 November 2012 at 10:58 AM
@3anson - the 288 poly count is the low-res count before subD. LLF teaches to model with as low as a poly count as possible, which I struggle with. I am used to working with more polys.
@LaurieA - yes, I originally posted that poly count was 67,162 faces, but I did not take into consideration that the V4 .obj was being counted as well. I was reading the stats wrong.
@paganeagle2001 - your info and screen shots are priceless. I very much appreciate your help and the input of the others. Later today I will make the subD's and test. Too many "honey-do's" right now.
Thanks to all.
C~
charlie43 ( ) posted Mon, 19 November 2012 at 7:59 PM
@pqgnqeagle2001 - the following 2 images are the wireframe images you requested. They are of the low-res and subD'd mesh. The third image is my final results. I used LaurieA's sim of 100 frames with pose @ frame 75 for these results. I set fold resistance at 1.0 as she also advised. One thing I am finding is when I bring the obj into Poser, I have to scale it up to 105% and also scale on the X & Zed axis to make it fit. It should come in fitting as well as it does in Blender, I would think. I also tried to set groups in AGE, but had the same scale issues. I am about ready to give up and start over. I have never had this issue n the cloth room before. This is very discouraging to me. I went so far as to subD 3 times, giving a face ciount of 34+K, and tried everything in between. This is getting ridiculous. Possibly someone can immediately spot the iossues with my mesh. Thanks to all who have contributed...
C~
Low-res mesh
charlie43 ( ) posted Mon, 19 November 2012 at 8:00 PM
This is the SubD mesh...
SubD Mesh
charlie43 ( ) posted Mon, 19 November 2012 at 8:02 PM
And this is my final render after leaving the cloth room...
final render
RedPhantom ( ) posted Mon, 19 November 2012 at 8:19 PM
Site Admin
I think that is a great improvement as far as smoothness of the drape on the shoulders and sides. The underarms look to me like you have the arms intersecting with the sides of the body (see picture) which won't allow for proper draping.
LaurieA ( ) posted Mon, 19 November 2012 at 11:25 PM
You can't pinch dynamic cloth. It will go nuts in those areas. Dynamic cloth isn't suitable for all poses.
