Fri, Dec 13, 9:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 13 7:48 am)
Subject: ? hole cut through a security fence
estherau ( ) posted Sat, 29 December 2012 at 7:58 PM · edited Fri, 13 December 2024 at 9:03 AM
I'm sure I saw a photoshop brush set or a model of this just recently somewhere?
Anyone seen anything like this?
Love esther
MY ONLINE COMIC IS NOW LIVE
basicwiz ( ) posted Sat, 29 December 2012 at 8:52 PM
Would a transparency map positioned where you want the hole not accomplish this? Sounds like the easiest way I can think of, given all of the background involvement I suspect is attached to this issue.
estherau ( ) posted Sat, 29 December 2012 at 8:54 PM
yeah I tried that.  the texture was tiling. would have looked okay though had it worked.
Love esther
estherau ( ) posted Sat, 29 December 2012 at 8:55 PM
but I can render with and without the fence in photoshop and cut a hole in post if I don't need too many different shots of same part.
Love esther
basicwiz ( ) posted Sat, 29 December 2012 at 8:57 PM
Sounds like an easy answer, to me.
primorge ( ) posted Sat, 29 December 2012 at 11:01 PM
What fence model are you using? Is it an available freebie? could be done in a matter of minutes depending on the model (actual modeling or transmap).
Have you seen this?
estherau ( ) posted Sat, 29 December 2012 at 11:05 PM · edited Sat, 29 December 2012 at 11:07 PM
Yep I did actually see that one but my fence is internal with more clasical looking wire. the fence is from a stonemason set.
ASWireFence.obj
primorge ( ) posted Sat, 29 December 2012 at 11:09 PM
Anyway, the artist is Ancestorsrelic... http://www.sharecg.com/v/61825/gallery/5/3D-Model/Electric-High-Security-Fency-system-as-OBJ
Check out his gallery of other freebies and his renders as well, just great stuff.
primorge ( ) posted Sat, 29 December 2012 at 11:12 PM
ah well, don't have that particular .obj... I'm sure that the solution is pretty simple though.
estherau ( ) posted Sat, 29 December 2012 at 11:18 PM
I think I only need one shot of it so I'll go the post work solution.  thanks.
Love esther
primorge ( ) posted Sun, 30 December 2012 at 2:06 AM
Anyway, I was bored... so I rummaged around and made this quicky image... "Depressing Fence With Hole".
Transmapped single poly planes, and my HiResPlane prop with morphs (render took about 8 minutes I guess).
estherau ( ) posted Sun, 30 December 2012 at 2:07 AM
that does look very good.
Love esther
estherau ( ) posted Sun, 30 December 2012 at 2:21 AM
actually it looks real.
primorge ( ) posted Sun, 30 December 2012 at 2:28 AM
thanks, but both you and I know that it looks like crap. Like I said I was bored... I occasionally will post quicky images as part of my "Troll Renders" series. Chuckle.
here's the hole section of the trans.
estherau ( ) posted Sun, 30 December 2012 at 4:02 AM
u might think that. I think it would look fine with other stuff around.
Love esther
primorge ( ) posted Sun, 30 December 2012 at 4:28 AM
You ever need help with simple odds and ends for your comic (If it's something that I'm capable of doing and I'm not in a funk) don't hesitate to ask, esther.
estherau ( ) posted Sun, 30 December 2012 at 4:34 AM
thanks.  that sounds really cool.
I am sure I'll take you up on that one. I'm always needing broken and fixed things and little wiring things etc.
Love esther
estherau ( ) posted Sun, 30 December 2012 at 5:51 AM
this was the best I could do using post work in photoshop and rendering twice.
Love esther
samhal ( ) posted Mon, 31 December 2012 at 9:12 AM · edited Mon, 31 December 2012 at 9:13 AM
Don't know if this will help, but the first thing that came to my mind was PhilC's scissors:
http://www.philc.net/Scissors_page1.htm (hope this link is ok to post here)
You use it directly on the obj.
i7 6800 (6 core/12 thread), 24 GB RAM, 1 gtx 1080 ti (8GB Vram) + 1 Titan X (12GB Vram), PP11, Octane/Poser plugin, and a partridge in a pear tree.
Oh, and a wiener dog!
WandW ( ) posted Mon, 31 December 2012 at 9:33 AM · edited Mon, 31 December 2012 at 9:34 AM
Quote - this was the best I could do using post work in photoshop and rendering twice.
Love esther
That looks pretty good.  You could try a magnet on the hole area to distort  the fence  a bit.
Happy New Year, Esther! 😄
Love, Rod
primorge ( ) posted Mon, 31 December 2012 at 2:15 PM
...poor results with a magnet or morph for distortion when you consider that most transmapped planes of this sort are a single poly. ditto with PhilC's scissors. Not familiar with the fence that esther is using, but knowing that it is a Stonemason .obj and his mesh economy, highly doubt there is alot of polys.
estherau ( ) posted Mon, 31 December 2012 at 5:14 PM
You are correct - the morphing brush wouldn't even show up on it.  But anyway it's a distant scene so it doesn't look too bad.  At a later date I will need more hole cut fences though.
Love esther
