Thu, Feb 27, 12:51 AM CST
Forum Moderators: RedPhantom
Subject: Nea 3 - detail work
  • 1
  • 2
pitklad ( ) posted Sat, 01 September 2012 at 10:29 AM · edited Thu, 27 February 2025 at 12:06 AM
I started working some detailed shaping morphs for [Nea 2](http://www.sharecg.com/v/46646/view/11/Poser/Nea-2.12)
which I guess will lead to Nea's 3 default face shape
I believe this time I push our beloved Posette's mesh to the limits
I try to use every single vertice available to make the look as smooth as possible
the areas that are reworked are eyelids and nostrils
both morphs are based on photo references
My FreeStuff
pitklad ( ) posted Sat, 01 September 2012 at 10:36 AM
and here is the nostrils rework
My FreeStuff
pitklad ( ) posted Sat, 01 September 2012 at 10:44 AM
another view of the nostrils
maybee I'll smooth a bit the border of the nose wings...
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 1:37 AM
and those are some wireframe images that show how the flow has changed
My FreeStuff
mylemonblue ( ) posted Mon, 03 September 2012 at 2:06 AM · edited Mon, 03 September 2012 at 2:11 AM
Dang! You moved a lot of polys to put more of them to use on the inner side of the eyes where posette's eye usually comes up short otherwise. The mesh flow on the face looks to be improved because of that and how you evened out the whole flow on the face. Beautiful work.
My brain is just a toy box filled with weird things
pitklad ( ) posted Mon, 03 September 2012 at 2:12 AM
thanks for the responce!
Posette had many polys that where compresed or hiden on the inner eye area
I slided all those polygons out on the eyelids and redesigned them completely using every poly as good as possible! repositioned the lashes that also were re-desinged bigger and to accept better textures, also the lacrimal was designed completely with polygons that already were there but were used purelly
My FreeStuff
mylemonblue ( ) posted Mon, 03 September 2012 at 2:36 AM
Looking at Nea 3 just made me re-learn and old lesson on how it's where you put the polys that counts. I've been told by more experienced 3D artists that some people make a mistake by just throwing more polys on models that don't need them. I think this shows that there is some trueth to that.
pitklad ( ) posted Mon, 03 September 2012 at 2:53 AM
I will agree with you
It is incredible what can be done even with not too many polys IF the positioning is right
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 8:22 AM
and here is Nea 3 shaped to fit the perfect face ratio
however it looks a bit too long face to me
My FreeStuff
monkeycloud ( ) posted Mon, 03 September 2012 at 8:31 AM
Wow! That's some phenomenal bit of poly tweaking there Pitklad! Excellent work 👍
pitklad ( ) posted Mon, 03 September 2012 at 8:55 AM
thanks **monkeycloud** it all has been done by hand on wings 3d, sliding vertices and moving points
here is how Nea 2 fits on the mask**
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 9:02 AM
and here is the medium solution, not perfect match but still not long face
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 9:05 AM
maybee I'll have to make the nose bridge wider
like angelina's
My FreeStuff
monkeycloud ( ) posted Mon, 03 September 2012 at 9:16 AM
Interesting that you're using Marquartdt's Golden Ratio based face mask there...
...a useful comparative tool, even if not going for "perfect" proportions, and instead adjusting according to taste etc.
Cool 😉
mylemonblue ( ) posted Mon, 03 September 2012 at 9:16 AM
I think that's it. The nose bridge being wider might balance it all out. ^-^
monkeycloud ( ) posted Mon, 03 September 2012 at 9:19 AM
Yup... definitely would agree with slightly widening the default nose bridge too...
pitklad ( ) posted Mon, 03 September 2012 at 9:55 AM
here is the nose bridge wider
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 10:47 AM
This is close to final
wider nose and nosetip, nostrils wider and lower, upper lip smaller
My FreeStuff
pitklad ( ) posted Mon, 03 September 2012 at 1:25 PM · edited Mon, 03 September 2012 at 1:25 PM
and here is a PP12 render with EZskin and smooth on
There are some texture distortions on the lashes due to morphs but I'll iron those out later...
My FreeStuff
mylemonblue ( ) posted Mon, 03 September 2012 at 2:44 PM
Even better. Incredible to see posette become this good looking. Truely amazing. ^o^
primorge ( ) posted Tue, 04 September 2012 at 4:58 AM
Excellent! Your dedication to the Nea project is admirable... Nice that your doing all of this in Wings, too. Great app.
Looking forward to Nea 3.
pitklad ( ) posted Tue, 04 September 2012 at 5:08 AM
Actually it is combination of wings, poser magnets & poser morph tool
Nea 3 is still just a thought, it relies on my free time
Nea is a constant experiment and I've learned a lot making her
There is a lot of poser tecnology in her, body handles, alternative geometry and some tricks to make all that work. She was a motive to dig deep in poser files and figure setup and modelling too, eyes and teeth are original geometry
My dream is that Nea 3 would come with a weight mapped version too, but I don't have the courage to learn all this new stuff
My FreeStuff
primorge ( ) posted Tue, 04 September 2012 at 5:36 AM
Well, don't forget all of us dinosaurs that aren't using the latest version of Poser when Nea 3 does make her debut... perhaps WM and non WM versions. Although I could probably get The WM version to work in Carrara.
Kudos.
pitklad ( ) posted Tue, 04 September 2012 at 5:46 AM
She will definately come in two versions IF there will be a WM version anyway
At the current state Nea can use Posette clothes so not many changes have been done to her joints, and I don't plan to change the body shape
Nea 3 if she ever makes a debut will be a face reshape and maybe she will have a new original UVS
My FreeStuff
primorge ( ) posted Tue, 04 September 2012 at 6:21 AM
A question about Nea 2.12...
I have Version 2.12b that I downloaded from ShareCG... Is this installation compliant with RTencoderpy? I can only decode files that were created with version 1 RTencoder as I am on a mac and RTencoderpy is my only option.
thanks
pitklad ( ) posted Tue, 04 September 2012 at 6:31 AM
I believe that even if the RTEncoder program is other version the rte file format hasn't change it can be decoded with any version
I myself used the first version of RTencoder which should be older than RTEncoderPy
as for the version 2.12b it is mostly a correction to folder and maybe texture and minor character errors
Please let me know if you have any critics or suggestion for improvement when you install Nea :biggrin:
My FreeStuff
primorge ( ) posted Tue, 04 September 2012 at 8:26 AM
RTencoderpy 1 worked (note to archaic Mac Os users)...
Thanks, pitklad.
I'll try to make some things for her...
pitklad ( ) posted Tue, 04 September 2012 at 10:46 AM
I'm glad you made it :biggrin:
I hope you will find her usefull!
My FreeStuff
pitklad ( ) posted Sat, 05 January 2013 at 7:46 PM
I am still slowly work on this
here is the current state of the face shape
left Nea 2 - right Nea 3 wip
My FreeStuff
Tessalynne ( ) posted Sat, 05 January 2013 at 7:58 PM
Very nice!  I do hope that Nea 3 does come to be.  I enjoy Nea 2, oh, my thanks for commenting on my gallery image with  her over at RDNA.
pitklad ( ) posted Sun, 06 January 2013 at 3:00 AM
I also hope to find time to finish this project
There are dramatic changes on eyelids that I'm afraid will make all current eye morphs useless... nose is also quite different. Many morphs will need to be reworked and the UVS to avoid texture streching.
It is so rewarding to see Nea on a gallery, thanks for using her! And I also loved that you use alternative figures on your images this makes your gallery have a great variation and freshness!
My FreeStuff
pitklad ( ) posted Sun, 06 January 2013 at 7:33 PM
Attached Link: Golden Ratio
Tried some other mesuraments  based on the golder ratio
found in a cosmetics site
this shows some more corrections that should be done
My FreeStuff
lmckenzie ( ) posted Sun, 06 January 2013 at 9:39 PM
Spectacular work! I hope you complete her. As long as there's a Poser, there should be a Posette.
JoePublic ( ) posted Mon, 07 January 2013 at 12:14 AM
Great job. :-)
I still enjoy rendering Posette occasionally.
pitklad ( ) posted Mon, 07 January 2013 at 3:30 AM
Cool render JoePublic
Posette is a great base to start and most of all fun and easy to work with
My FreeStuff
momodot ( ) posted Mon, 07 January 2013 at 12:18 PM
@pitklad - So cool you are working on this. Looks great. Definately the wider nose tip and bridge is better I think. I find your approach using ratios is very interesting. Have you ever played with Blacksmith3D's HeadForge? I found playing with random asymetries very interesting.
@JoePublic - that is a beautiful face. Hard to beieve it is Posette. Fine work!
I hope all is well in life for you guys :)
JoePublic ( ) posted Mon, 07 January 2013 at 5:07 PM
Now look what the cat dragged in !
Long time, no read, my friend.
How's it going in the great white north ?
momodot ( ) posted Mon, 07 January 2013 at 5:14 PM
all good here :)  same old thing mostly. pretty mild winter so far actually.
JoePublic ( ) posted Mon, 07 January 2013 at 5:26 PM
Same old, same old.
Pretty warm winter here, too, so far. Although last year it still got really, really cold in February.
Anyway, don't want to highjack Pitklad's thread.
I'm currently weightmapping David 3. Give me a call if you want to have a peek.
Mail is still the same.
pitklad ( ) posted Tue, 08 January 2013 at 1:59 AM
Hello momodot my friend! I'm so happy to see you here again!
I hope you are well! My best wishes for the new year!
My FreeStuff
momodot ( ) posted Tue, 08 January 2013 at 4:15 PM
Hello pitklad. I often think of you and hope you are well. Things are well with me:)
edgeverse ( ) posted Fri, 11 January 2013 at 9:11 PM
Nea 3 is looking fantastic
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
momodot ( ) posted Sat, 12 January 2013 at 9:16 PM
@JoePublic - I lost my old address book so sent you an IM here at Renderosity but if you are like me your rarely check your IMs. Same email address for me.
Sorry to post this in your thread pitklad :) Really the Nea work is nice!
pitklad ( ) posted Sun, 13 January 2013 at 9:15 AM
Attached Link: Nea 3 face wip
No worries my friends! :biggrin:
here is a PP12 render of Nea 3 that I uploaded on my gallery here, I want to believe that the face shape is almost final
My FreeStuff
ima70 ( ) posted Sun, 13 January 2013 at 11:23 AM
Beautiful, I like the face a lot but most of all I love her eyes!
pitklad ( ) posted Mon, 04 February 2013 at 4:29 AM · edited Mon, 04 February 2013 at 4:30 AM
I spread some polygon edges so that can be used better for morphing and to get a smoother look, taking advantage of the current resolution as much as possible
mostly in the space between the eyes and brows, also rolled some polygons from the back of sculp on the forehead
My FreeStuff
pitklad ( ) posted Mon, 04 February 2013 at 4:32 AM · edited Mon, 04 February 2013 at 4:34 AM
Skull was also reshaped to give a better bald look :biggrin:
My FreeStuff
primorge ( ) posted Mon, 04 February 2013 at 10:16 AM
Coming along nicely, pitklad. That's a lovely profile shot.
mylemonblue ( ) posted Mon, 04 February 2013 at 10:18 AM
Thanks for sharing more of your progress on Nea 3. Looking good!
It really shows how good mesh flow can improve a figure. =)
pitklad ( ) posted Mon, 04 February 2013 at 2:34 PM
Next area for improvement will be the ears
Also I may rework the lower lips a bit more
It is hard to smooth the mesh without making the face structure look too undefined
so I rearange the edges on wings than brush with the poser morph tool for smooting at low settings and than rework the mesh in wings if needed
all test renders are made with poser smooth on since it is always needed for Nea's low resolution, so she is redesigned with this in mind
My FreeStuff
momodot ( ) posted Tue, 05 February 2013 at 2:05 PM
That profile is really nice!!!
  • 1
  • 2
