Sun, Dec 1, 6:08 AM CST
Subject: Can't download from FreeStuff
masha ( ) posted Mon, 14 January 2013 at 12:04 AM · edited Fri, 26 July 2024 at 5:11 AM
In the Details page I used to have to click on  something like " If your download doesn't start within 10 seconds click here." and it would download the item.  Now that little link is gone and the Download button doesn't work for me. Anyone else with the same prob? Or a solution?
Thanks.
AlanaDale ( ) posted Mon, 14 January 2013 at 12:15 AM
maybe they would know in the "FreeStuff forum"
masha ( ) posted Mon, 14 January 2013 at 12:26 AM
oh ok will check it out, thanks. I was after some Tyler freebies and oddly, I downloaded 2 successfully before that above-mentioned link disappeared  and I coudn't get the rest.
masha ( ) posted Mon, 14 January 2013 at 12:52 AM
Solved, thank you. Must have been a temp Firefox problem.  After I restarted it the link reappeared.
ashley9803 ( ) posted Mon, 14 January 2013 at 2:40 AM
I think you need JavaScript turned on in Firefox for the DL link to work. I've had it disabled lately because of all the Java exploit warnings about.
LaurieA ( ) posted Mon, 14 January 2013 at 6:30 AM · edited Mon, 14 January 2013 at 6:32 AM
javascript and java are NOT the same thing. You can run javascript just fine. It's Java you need to turn off in your plugins. Not javascript. Bad things can happen with javascript as well, but in this case javascript isn't the problem. If you don't want bad javascripts to make their way onto your computer, just use NoScript. Turning off java in your plugins panel  - well, you'll likely never notice unless you play java games and stuff ;).
