Sun, Dec 1, 5:42 PM CST
Subject: Pivot Point
odeathoflie ( ) posted Fri, 14 September 2001 at 12:01 AM ยท edited Fri, 29 November 2024 at 12:42 PM
Attached Link: http://www.geocities.com/odeathoflife/SpiderManMovie.htm
Hi I am tryign to create a spiderman animation, but the webs are giving me troubles, I want to be able to lock one end to spidys hand and the other to the building (I know you cannot parent an object to 2 different things) so am trying to figure out how to change the pivot point of the webs in hopes of that giving tthe effect of being attached to a wall. I looked in the obj properties dialog box but there was only visible check box there, any help will be rewarded with the knowledge that you helped a moron heehee. Thanks for your help odeathoflife attached is an animaton of spiderman without the webs it is compessed with Divx4
Nance ( ) posted Fri, 14 September 2001 at 2:04 AM
Although you cannot parent to two objects, sometimes you can work with "Parent" & "Point At" to keep an object properly oriented to two points as you move it.
ShadowWind ( ) posted Fri, 14 September 2001 at 2:34 AM
Sorry I can't help you on the question, but got to say that that animation (even without the webs) is fantastic. His motion is so natural...
odeathoflie ( ) posted Fri, 14 September 2001 at 7:57 PM
thanks shadow, there is only 3 poses used at 25 frame intervles, turned out great
