Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Whe I look at your scene I understand that the motor does not have a shadow.
Your light, as I can judge from the lantirn and its shadow, is coming from below and from the right hand corner, shining upwards to the left upper corner of your scene.
A light coming out of the ground and shining UPWARDS can not put a shadow of the motor on the ground.
Take a look through your shadowcams and see what your lights see and where your lights WILL put their shadows.
What I do not understand is why the pig head does not have a shadow. Only the suit casts shadows. Check your settings for that figure.
But : A light coming from below shining upwards can never put a shadow on the ground.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Shadow cams? See you talk about being a noob. Light from the ground was suppose to light the building. Even tried a spot on the road shinning left on the bike. Ok I will continue to struggle. If others do it with such fantastic realistic scenes, I have my goal and will do it.. (no matter how long it takes me lol.)
I also tried each prop, character to have a light emitter. Then turned them all off. Didn't see any change.
Thank you so much for your quick reply
Win10 Poser 2014/Poser 11 Daz3D
Like that pig--he's a sharp dresser.
If you select your light, youll see all the parameters listed to the right. Make sure your light is above ground--the Y Tran setting. Look under the Properties tab to see if the light is visible or not.
When I want to check positions of my lights, I ususally use the top camera. If the lights arent INSIDE the building, you should be able to see them. If they are under a roof or something, youll need to make the roof object invisible to see the light.
Poser Pro 2014
My personal website:
Novels, photos, video, sculptures and more
Evidence of a Lost
City: An animated movie and novel, in progress
Hag: A novel and live-action movie
The only real problem I see is why the pig's suit gives a shadow, but he does not.
If you put a light from left to right, up to down on the bike to test?
Test with an infinite light, and turn all the other lights off.
Somtimes a shadow gets washed away by other lights.
look through the shadowcam for that infinite light and see what the light sees.
Then agjust the light to your liking.
Then one by one, load the other lights again, and check what lights blow your shadow away.
Also check the Y position of the road. is it above or below the ground plane.
Is the road marked as shadow catching.
Sorry, many questions, I know.
Go step by step,
happy Posering
Tony
Dev
"Do not drive
If the stores are all one prop, you can make the whole street-stores invisible with one click, so youll just see the characters, cameras and lights. Again, selet the stores, go to the Properties, uncheck Visible.
Poser is one of those programs that reward experimentation, so your playing around with all these things--tho exasperating and time consuming--is the way to go. It nevere seems to end, for me at least. I learn a batch of new things, and then see a whole landscape of more things to learn, all of them too too complicated...so keep at it!
Poser Pro 2014
Evidence of a Lost
Another tip for super noob.. Believe it or not I actually tried reading the 'MANUEL'
Bunch of super people here with great advise...
Ok will rework this render. Personally I do like it but not my results...I'll repost it to compare. Can't guarantee it will be soon...My tolerance of failure is -1...
If it is supposed to be an outside daytime scene, use BB's environment sphere and one infinite light at about 40% and turn on IDL...
Edit here's the link to the sphere...
https://sites.google.com/site/bagginsbill/free-stuff/environment-sphere
"Oh - the manual says that? I have never read the manual - this must be why."definately 100% what WandW said. this scene will be given a boost of life using an environment sphere + 1 light instead of your multi-like approximation. The sphere surrounding the scene will produce light that bounces around the scene lighting things from all angles realisticly, thanks to Indirect Diffuse Lighting (IDL). You then just need one light, I'd suggest a point light myself with linear falloff. The single light will create your shadows so it is highly advised to use ray-traced shadows.
If you have a 3D graphics card in your computer thats not ancient, go into the render settings, choose the "preview" tab select OpenGL as the display engine and tick "enable hardware shading" and "enable hardware shadows".
Your preview in Poser will now show a low quality preview of the shadows you will get in realtime making it SUPER easy to setup your one shadow casting lite!
TemplarGFX
3D Hobbyist since 1996
I use poser native units
IMO. the lights are too bright. If the store front is entirely enclosed, there should be no, if little, interior lighting to be seen. Those should be in shadow. Considering that you are using PP2012, IDL will solve some of your problems. As mentioned by others, start with one light, an infinite for your sun and decide where you want to place it in your scene. Is the scene in broad daylight, bright sunny day @ noon or overcast with very even direct lighting and faint shadows? Add a sun color; gray for cloudy conditions, yellow for sunshine. Just place that single light where you find it pleasing in the scene. This will be your key light with shadows.
Next, add your fill lighting which will either add or not add more shadowing. This is where a skydome comes into play. It is an ambient light, it will fill and soften shadows. It is also diffuse lighting with no specular value. Other lights associated with light fixtures can provide additional fill lighting which will provide more subtle or distinct shadows. This up to you.
But add you lights slowly and one at a time. Position them until you are satisfied with their placement.
Get a Skydome and a texture to match (HDRI preffered)set as emitter,scale to envelop scene and delete one of those distance lights. Enable IDL in render settings.
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Quote - This is scene zoomed out. Is BB EnvSphere suppose to cover the whole background?
Yes, that's what it should look like, although usually I use the dome for lighting if it's not going to be visible. To use the sphere in this scene, I'd put a plane primitive under the scene to block the light coming up from below; make it big, like 100 ft or more across, and make sure cast shadows is on in its properties. It looks like you applied the gradient material to the sphere, which is fine.
Did you add an infinite light and enable raytraced shadows, and turn on raytracing in your render settings?
"Oh - the manual says that? I have never read the manual - this must be why."Thinks this looks better..
Point out my errors once again...Said I wud give up. lol..This scene is haunting me in my dreams
This is a quick setup I did with the PP2012 Raleigh Tavern with one infinite light at 35% and a point light in the foyer at 5%
To set up Renders in PP2012, I use the included D3D script, found under scripts>Partners>Dimension 3D>Render Firefly, which shows everthing and allows you to save various settings. Make sure Enable Indirect Light and Enable Raytracing and Use Irradiance Cache are checked, and that raytracing and shadows are enabled on all of your lights.
Load the dome, apply the gradient material in its folder in tha material folder, make sure that cast shadows is checked in the properties of your Ground plane, delete (or set intensity to zero)all of your lights except one infinite at 35%, which will be the Sun, so it should be coming down from the right (based on the shadows of your first render)...
Edit; if you have reflective surfaces, set raytrace bounces higher than 1...
"Oh - the manual says that? I have never read the manual - this must be why."Sorry. Rechecked and part of LeVillage Bistrot'
From my viewpoint, the textures are perfectly fine for rendering. As recommended, build up the lighting individually until you get the effect that pleases you, but don't forget view the lighting in a realistic manner.
I think that is a vast improvement. Yes, over 3 hours is to be expected on a full render. If you change anything, I suggest lowering some settings and do area rendering instead. It will cut down time. Or reduce your resolution using D3D Firefly renderer, that will take the load off full rendering until you are pleased with the results. I like the results so far.
Here's a thread on fast IDL renders with settings from BB for speeding things up; scroll down a bit for the settings he used and why...
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3572082
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Have alot of trouble trying to locate my lights in a scene. Even zoomed all the way out. Use the parameters to move around but between using dynamic clothes (noob) using a store prop etc etc went back and forth 3 weeks . Still not happy with it. Have alot of problems with the shadows on the characters...Also for the life of me I cud not get the motorcycle to reflect shadows on the ground prop. Normally U would use 2 spot and 1 infinite.. Being not too bright (that has to be the reason) I could not get one spot on upper left and one upper righ, to show up in the scene.. This scene I used 2 point and one infinite then went into PhotoShop to brighten it up..Any advice for a frustrated Poser2012 noob?
