Fri, Nov 29, 5:49 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Subject: Vue & Maya, same scene, not same frame. Need help!
Narone ( ) posted Fri, 19 April 2013 at 3:42 AM · edited Fri, 29 November 2024 at 2:58 PM
Hey,
Need to have a shot ready for monday and have rendered the beauty pass from vue and the Z pass didn't work so need to render it from maya but i open the same scene with the plugin in maya but the frames doesn't correspond.. i.e i go to frame 321 in maya but the same frame in vue is 335.. in short the passes from maya won't fit my beautypass..
I have tried all i can think of, even tried to make the depth pass (id and depth are my concern) in nuke but the scene was too heavy to get out in time.
Could mention im fairly new to vue so i hope there is just something i have missed.. Using Vue10 xStreme with maya 2012 btw.
If someone here might have a hint on why the frames are not the same i would really need your help, getting a bit desperate now.
ShawnDriscoll ( ) posted Fri, 19 April 2013 at 9:14 PM
Narone ( ) posted Sun, 21 April 2013 at 6:20 AM
Thanks for the tips but unfortunately i have already checked the fps and its the same.
I have now however found a checkbox under the vue plugin in maya which said something about correct frames and it did make it a little better but then noticed in 6 frames spread out in the scene it flipped the camera about 180 degrees for some reason and a few frames before and after to correct the flip so did not help either.
ShawnDriscoll ( ) posted Sun, 21 April 2013 at 8:28 AM
Camera height locked?
Narone ( ) posted Sun, 21 April 2013 at 11:27 AM
No had that problem at start so thats also fixed. It all follow the patch of the camera correct except that it is off, more backwards at the start and more forward at the end so almost feels like some kind of a proportion problem.
ShawnDriscoll ( ) posted Sun, 21 April 2013 at 2:13 PM
Vue deos smooth tweening for camera movement by default.  I have to turn it off and set to linear tweening for start/end keyframes.  Then camera velocity is constant.
Narone ( ) posted Wed, 24 April 2013 at 9:49 AM
We decided to do a comp solution this time, the only way to manage in time but will still try and find out why it got all the problems so i know until next time i get the same problems.
Thanks Shawn, will try that and see if it might help
