Fri, Dec 13, 7:46 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
Subject: silly question but how do I get rid of all the extra material nodes
estherau ( ) posted Sun, 05 May 2013 at 1:25 AM · edited Fri, 13 December 2024 at 7:46 AM
I have for a figure, that aren't actually being used ie for zones that don't exist?
MY ONLINE COMIC IS NOW LIVE
ghostman ( ) posted Sun, 05 May 2013 at 1:59 AM
Tried Snarlys Mat helper?
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
estherau ( ) posted Sun, 05 May 2013 at 2:17 AM
I'll take a look - thanks.
primorge ( ) posted Sun, 05 May 2013 at 3:53 AM · edited Sun, 05 May 2013 at 3:58 AM
If you're referring to the actual material groups of the figure you will have to remove the material lines from the .obj and the .cr2 in a text editor. whatever you do though make sure to retain the preview material in the .cr2 or your figure will be invisible.
_I think that one of PhilC's utilities can automate this, Poser Pocket Knife or Poser Tool Box...
estherau ( ) posted Sun, 05 May 2013 at 3:57 AM
you think I need to hack the Cr2 and the .obj?
I'm hoping there will be an easier way.
Love esther
primorge ( ) posted Sun, 05 May 2013 at 4:02 AM · edited Sun, 05 May 2013 at 4:03 AM
I just did it last night in order to get rid of unnecessary material groups (created in wings) that I used for establishing groups for rigging... It's a PITA but it's the only way I know of to get rid of the zones. Ummm, If you try overwriting with the grouping tool it just adds that additional zone.
Poser needs an in house way of deleting material groups. (Maybe there is a way that I'm not aware of).
primorge ( ) posted Sun, 05 May 2013 at 4:05 AM
... Hacking the files is really the most precise way.
estherau ( ) posted Sun, 05 May 2013 at 4:08 AM
I'll have a look at snarly's script.  If I can't find a script I'll just keep my unecessary groups I think.  they aren't really causing much of a problem.
Love esther
heddheld ( ) posted Sun, 05 May 2013 at 4:30 AM
@primorge!! big thanks you just solved a problem thats been bugging me for a week aaarrghhhhh (was deleting preview mat when tiding up some stuff  doh)
primorge ( ) posted Sun, 05 May 2013 at 4:39 AM
Open the .obj as text, after Vertex normal lines you should begin to see group/facet info... delete usemtl:'material you want to get rid of name' (see blue highlighted). save back out as .obj after chopping all the materials that you don't want in there.
primorge ( ) posted Sun, 05 May 2013 at 4:42 AM
open the .cr2 as text, near the bottom of the file you will begin to see the material definitions 'title material you want to get rid of" delete all lines up to next material definition. hunt down and delete all undesired materials . save back out as .cr2. load in poser and test. always work from copies.
primorge ( ) posted Sun, 05 May 2013 at 4:44 AM
 do this successfully and those material zones will no longer be present in the material room. There's probably an easier way but this is how I do it.
ockham ( ) posted Sun, 05 May 2013 at 6:00 AM
Ditto Primorge.  It's a little easier if you always run the OBJ through UVmapper to eliminate the vn lines.  UVmapper also reorganizes the file so all the v's and vt's are together on top, and the groups and usemtl's are based solely on the facet lines.  This makes the part with groups and materials much more compact and easy to scan visually.
My python page
My ShareCG freebies
primorge ( ) posted Sun, 05 May 2013 at 12:05 PM
Thanks for those tips ockham. It seems many times this kind of information can only be found by hours of tinkering and happenstance. BL Render's 'secrets of figure creation with Poser 5' has also been a tremendous help, too.
estherau ( ) posted Sun, 05 May 2013 at 5:52 PM
I thikn philCs pocketknife may do the job for me automatically.  Have'nt bought it yet though.
vilters ( ) posted Mon, 06 May 2013 at 7:02 AM
Material zones are in both, the obj file and in the cr2.
You will have to adapt both if you want to get rid of a material zone.
I merge material zones, and always do it in both.
That is why it is not so easy to do it inside Poser.
Poser would have to adapt the cr2, but also would have to save a fresh obj file.
vilters ( ) posted Mon, 06 May 2013 at 7:42 AM
Update, in Poser you can create extra material zones but you can not remove those that are in the obj file.
EClark1894 ( ) posted Mon, 06 May 2013 at 9:14 AM
Hmm, I didn't know that there were material zones in the object file. I've just been removing them from the .cr2 files and that's it.
vilters ( ) posted Mon, 06 May 2013 at 9:22 AM
When you create an obj file, you can group it and define material zones.
All depends on the possibilities of the modeler one uses.
Hexagon can do groups and material zones. Then they are in the obj file and Poser reads them as such.
All depends how the obj file was created.
Some create the material zones entirely in Poser, others do it in the modeler. These can only be deleted from within the obj file.
EClark1894 ( ) posted Mon, 06 May 2013 at 10:09 AM
I define my material zone in Blender, but I don't group anything until I go into Poser's Setup room.
primorge ( ) posted Mon, 06 May 2013 at 10:20 AM
Yeah... If you just delete the materials in the .cr2 (and they are present in the .obj) those materials will still be present every time you load the figure.
Probably best to create your groups and materials in a modeling app where the tools are more efficient than the horrible grouping tool, depending on the geometry it can be pretty frustrating when a single tucked away poly refuses to be selected (and this is in wireframe with multiple orthographic view selection attempts). Don't know if the group editor has been polished with Poser 9+, if not it certainly needs some working over.
EClark1894 ( ) posted Mon, 06 May 2013 at 11:25 AM
For the life of me, I can't get a handle on Poser's grouping Tool. Sometimes it seems to work for me, and other times it act's like I'm it's bitch!
DreamlandModels ( ) posted Tue, 07 May 2013 at 12:10 AM · edited Tue, 07 May 2013 at 12:15 AM
Attached Link: here is a link for you
I use Phil C's PZ3 Editor it has a delete materials plugin that does what you want with a couple clicks of your little mouse. Easy as pie! Just remember to save the file once the plugin is complete.
It is pretty cheap and does a bunch of cool stuff. Well worth the money!
Tom
primorge ( ) posted Tue, 07 May 2013 at 3:10 AM · edited Tue, 07 May 2013 at 3:12 AM
PZ3 editor= Windows only, esther.
_possibly could get it to work on an Intel mac with one of those doohickies (which you use if I remember correctly).
