Fri, Dec 13, 7:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 13 7:48 am)
Subject: Shaderworks library manager 2.6 - installation problems
remakez ( ) posted Mon, 27 May 2013 at 2:12 PM · edited Sat, 30 November 2024 at 8:12 PM
Hi,
I am trying to install shaderworks library manager 2.6 in to Poser 9. But I can't seem to get it right. I have moved the unziped runitme file to the main Poser runtime, but when I load Poser and go to scripts/partners/shaderworks it lists the following 3x options:
import_runtimes2012
Light Manager
Postwork Manager
But no - Shaderworks Library, this is driving me mad - can anyone please help??
Cheers
file into the run time folder - even tried putting it into python adding, but still doesn't work! Simple walk through would be great
Also I see that 2.6 is now out - would I have to repurchase to upgrade?
Thanks all
hornet3d ( ) posted Mon, 27 May 2013 at 4:21 PM
The Shaderworks Library in under Window - Addons not under the sripts menu, well it least it is if it is installed right.
ghosty12 ( ) posted Tue, 28 May 2013 at 7:34 AM · edited Tue, 28 May 2013 at 7:47 AM
The version of Library Manager from RDNA will have it's own listing in the scripts menu.  It should show up as Shaderworks in the drop down menu, with Library Manager in the sub menu..
Yes it can also show up in the Window Addons sub menu, but if you copied the runtime folder from the Shaderworks Library Manager zip file and put it into where the Poser 9 runtime is it will be in both the Window and Scripts menus.
You know you enjoy 3D Art when you realize that your life is a piece of 3D Art. :)
AMD 7900X3D, 64 GB Corsair Vengeance DDR5 Ram, Asus Prime X670-P Wifi MB, PNY RTX 4070Ti Super 16GB, 14TB SSD's & HDD, Windows 11, Poser 9 / Pro 2012 / Pro 2014, Daz Studio 4.22.
remakez ( ) posted Tue, 28 May 2013 at 8:25 AM
file_494816.doc
So - I unziped the Shaderworks file and moved the runtme filie in to the main Poser runtime and this is what I get - please see attached.
Their is no other options for Sharderworks in any of the other dropdwon menus.
I thought I might be moving it the the wrong file but the stallation notes so to suggest the above??
remakez ( ) posted Tue, 28 May 2013 at 8:29 AM
file_494818.doc
see attached showing where I am moving the shader runtime to in Poser.
ghosty12 ( ) posted Tue, 28 May 2013 at 9:29 AM
 Mmm not sure then if following the instructions in the zip file and still not showing might have to contact Semidieu the creator see what could be up with it..   Could be something as simple as the runtime folder being copied into the runtime folder, I know that I have done stuff like that many times..
Other than that not sure what I can suggest as at a loss myself why it is not working for you..
hornet3d ( ) posted Tue, 28 May 2013 at 9:47 AM
In your shaderworks.doc you are looking for the Library Manager 2.6 under the scripts menu, this incorrect.  To the left of the scripts menu is 'window'  click on that in the same way as you did the scripts and at the bottom you will see a sub menu of 'addons'.  In there you should find the Shaderworks Manager 2.6.  If you look at the runtime for the manager this is how it is structured, so if you merge this with the existing main runtime manager will appear correctly in the addons folder.
remakez ( ) posted Tue, 28 May 2013 at 9:57 AM
file_494820.doc
Looked there and still nothing? I am doing it correctly by moving the unzipped shaderworks runtime folder into the poser main runtime floder?
hornet3d ( ) posted Tue, 28 May 2013 at 10:00 AM
THis should help, ignore the right of the panel I am running two screens and that has nothing to do with it but the left panel should highlight where the library is.
remakez ( ) posted Tue, 28 May 2013 at 10:03 AM
file_494823.doc
But as you can see from the attachment - it's not there?
hornet3d ( ) posted Tue, 28 May 2013 at 10:19 AM · edited Tue, 28 May 2013 at 10:20 AM
Quote - But as you can see from the attachment - it's not there?
Then you do have a further problem - qoute from the shaderworks documentation
"Library Manager 2.6 is using a feature from the latest service release of Poser 9 and Poser Pro 2012: addons. This allows making a much more stable update system".
The structure of the supplied runtime is
 RUNTIME
        Python
                 addons
                 poserscripts
 That is what should be in the runtime of you main Poser 9 Runtime, at least it is with mine and it works, the only difference is that I am running Poser 2014 and 2012 before that and it worked in both.
I think I would check the downloaded zip to make sure that is correct and then I would copy the 'addons' and 'poserscripts' to the python floder in my main runtime.
hornet3d ( ) posted Tue, 28 May 2013 at 10:25 AM
This is how my folder structure looks.
paganeagle2001 ( ) posted Tue, 28 May 2013 at 10:44 AM
Create a new folder on yoru hard drive. Call it Install LM.
Copy your install zip into this folder.
When unzipping, use the Install here option.
You will now see a runtime in that folder.
Go insde of it and see how it has been set up.
Copy the files inside the various folders into the same folders of your Poser runtime.
This way you should get it working.
All the best.
Great Uncle LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
remakez ( ) posted Tue, 28 May 2013 at 10:58 AM
Finally managed to do it by moving the zipfiles one at a time!
Thanks ghostly and Hornt3d for sticking with me on this :0)
hornet3d ( ) posted Tue, 28 May 2013 at 11:06 AM
Your welcome,  glad you got it working.
It is great to have new features but it takes some getting used to, particularly when it make changes to a procedure that you have got used to.  No doubt more and more venders will use the addons folder so we will have the new structure and two places to look for scripts for a while in the future.
remakez ( ) posted Tue, 28 May 2013 at 11:08 AM
Thanks paganeagle2001 - pretty much did what you suggested:)
remakez ( ) posted Tue, 28 May 2013 at 11:25 AM
file_494825.doc
sorry - but do any of you know why I am having to manually locate bums??
See attached
hornet3d ( ) posted Tue, 28 May 2013 at 11:50 AM
Is your Poser 9 a new installation ? If so how did get Poser 9 to work with your old Runtimes.
Have you made any changes to your Runtimes and funally have you got your file search set to deep in the library tab under edit, general settings?
Normally this happens if the files required by Poser are not where it expect them to be.  If it is a new product the files could be in the wrong place, if it is a saved scene, it suggests something has changed since the scene was built and saved.  Setting the file search to deep can help but it does not change the file structure if the structure is wrong.
estherau ( ) posted Wed, 29 May 2013 at 5:28 AM
I bet it is a permissions proBlem. Befor I can install it into new version I have to change permissions on poser folder from read only to read write including Sub folders.
MY ONLINE COMIC IS NOW LIVE
randym77 ( ) posted Thu, 04 July 2013 at 9:08 AM
Does Shaderworks Library Manager work with Poser 10/PP 2014?
The product page at RDNA says it's for Poser 9/2012 only.
hborre ( ) posted Thu, 04 July 2013 at 12:56 PM
I believe the Python Script did not change between P9/PP2012 and P10/PP2014.  It should be recognizable and functional.
hornet3d ( ) posted Thu, 04 July 2013 at 2:46 PM
Shaderworks Manager 2.6 works in Poser 2014 as I am using it on a daily basis.  I do not think there were any updates for 2014, at least I have none in the backup.  There were some updates around the time but only becased some scripts were referenced to Poser 9.  I was an easy fix and all the updaes were done in a day or so.
Anything purchased today showing Poser 9/2012  should work with no problems in Poser 10/2014.
randym77 ( ) posted Thu, 04 July 2013 at 2:56 PM
Thanks!
