Thu, Feb 27, 1:43 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Keyboard Shortcuts Revisited
chud ( ) posted Mon, 03 June 2013 at 7:29 PM · edited Thu, 23 January 2025 at 9:03 PM
Can you add a menu item to the poser.xrc file if it doesn't already appear there ? I would like to add Copy Material, Paste Material & Apply material to all and then add keyboard shortcuts for them.
ockham ( ) posted Mon, 03 June 2013 at 7:56 PM
Yes, you can.
It works nicely, IF the command is already a main menu item.  I don't know if actions inside the material room would work that way.
If not, you can use another trick inside the ScriptsMenu folder.  Find or write a python script that forms the action you want, then give the script a filename that includes the hotkey.
For instance, I have a SnapTo script that I've rigged to act on Alt-Z.
The script is in the ScriptsMenu folder, and its filename is
SnapTo###Alt+Z.py
Taking this apart:
The title SnapTo
 then ###
then Alt+Z
then .py
My python page
My ShareCG freebies
chud ( ) posted Tue, 04 June 2013 at 1:20 AM
Thanks, ockham. I have no scripting skills, although I did manage to create a shortcut for duplicate.
