Forum Moderators: wheatpenny, RedPhantom
Freestuff F.A.Q (Last Updated: 2025 Feb 23 8:26 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Attached Link: Free Filled Bookshelf
A simple, but effective bookshelf, including books, that can be used in your contemporary architectural interiors, or as a background prop anywhere you may need to fill space with realistic furniture.The model is available as a native 3dsmax 2012 scene file (.max), and also in several scaled .obj formats, for importing easily into other applications, like Blender and Poser. All texture files are included for color and bump channels.
This item is currently available here in the Freestuff area here on Renderosity. Alternately, you can also download this bookshelf in .max and .obj versions from the following locations:
Turbosquid.com - Includes the .max scene file and .obj files as seperate downloads with texture files included in both.
ShareCG.com - This zip has both .max and .obj files, including Blender and Poser specific .obj scaled versions, all in one zip
The .max file should open without problems in Max 2012 or higher.
*** OBJ users, the Poser-specific OBJ version was exported with a scale conversion that should load with the appropriate scaling into most Poser 9 and above. To ensure proper import, BE SURE to DE-select all check box options boxes in the Import Options dialogue. DESELECT the "Centered", "Place on Floor", "Percent of Standard Figure Size", etc. options in the import dialogue box after you select the poser .obj file, and then the object should load with correct scale into the scene. In Daz|Studio, simply choose the Poser scaled .obj version, and import with Poser preset from the import dialogue box. Blender users, obviously, choose the Blender scaled .obj. All other software applications may be best suited to import the standard .obj file.
Hope you can find some use for it. Let me know if there's any problems or questions.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
