Sun, Dec 1, 4:24 AM CST
Subject: Default ground prop
vitachick ( ) posted Thu, 01 August 2013 at 4:20 PM · edited Sun, 01 December 2024 at 4:11 AM
Does anyone ever use it and if so what is the purpose. I normally make it invisible, delete all the default lights and just load a point light..
Win10  Poser 2014/Poser 11 Daz3D
geep ( ) posted Thu, 01 August 2013 at 4:45 PM
I use the Ground prop (wireframe) for scaling. 😄
(change the Scale of the GROUND to measure feet, inches, mm, cm, etc.)
Did someone say "Scale?" :lol:
cheers,
dr (bob) geep
cheers,
dr geep ... :o]
edited 10/5/2019
aRtBee ( ) posted Thu, 01 August 2013 at 4:50 PM · edited Thu, 01 August 2013 at 4:51 PM
@vitachick: you'd better change your default scene then...
vitachick ( ) posted Thu, 01 August 2013 at 5:31 PM
Change default scene..Ok how where? I add lights as needed btw
Thanks for replies.
ockham ( ) posted Thu, 01 August 2013 at 6:00 PM
Changing the default scene:
Get things the way you like to start, then on the main menu Edit:General Preferences.  Click on "Launch to Preferred Scene" then hit the Set Preferred Scene button.
Close Poser.   The next time you start, it will start the way you want.
My python page
My ShareCG freebies
vitachick ( ) posted Thu, 01 August 2013 at 7:20 PM
Great!
Thank you!
bagoas ( ) posted Fri, 02 August 2013 at 10:49 PM
In older Poser versions, the default ground prop was set up as a shadow catcher. So set up it gives the shadows the figure would have on flat ground  under the scene light. You can then layer the render over an image in Photoshop with more or less realistic ground shadow.
rokket ( ) posted Sat, 03 August 2013 at 11:54 AM
I've added textures and displacement maps to the default ground texture with decent results. Saves time modeling a landscape.
rokket ( ) posted Sat, 03 August 2013 at 1:10 PM
This was a quick throw together and I missed on the lighting, but you can see the ground plane works quite well with displacement and texturing.
vitachick ( ) posted Sun, 04 August 2013 at 1:05 AM
Going to try it Rokket!!
rokket ( ) posted Sun, 04 August 2013 at 1:37 AM
Let me know if you need any tips. One I can give you right now is that you will have to reposition your figure to account for the depth of the displacement.
