Forum Moderators: RedPhantom
A child group must only touch its parent. Is it also touching a sibling?
Is the right thigh only touching the right buttock or is it also touching the left buttock? If so you'll see a split.
Not withstanding the above it is possible to overcome this by editing the CR2 file but my thinking is that it is best to understand the problem and know how to avoid it rather than to apply band aids.
I rigged a simple OBJ skirt, but after doing so I get a split in the mesh at the back of the skirt when bending thigh/buttockI thought this was due to not being welded or connected in the mesh, as some of the vertices stick, and some don't. I took the OBJ into Blender and removed doubles, but no changes. I also took it into Hexagon, and moved around the vertices, edges and faces, and nothing splits...???
What else could be causing the split.
To rig it, I just take it into the setup room, add the rigging bones, autogroup and return to pose room.
