Sun, Dec 1, 6:46 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Detecting hair props
Pret-a-3D ( ) posted Wed, 08 January 2014 at 9:14 AM · edited Sun, 01 December 2024 at 6:25 AM
Hi.
Is there a reliable way of detecting if and Actor refers to a hair prop. IsHairProp() surprisingly doesn't work (it returns False for Hait props) and I could not figure out any other option.
Any help will be greatly appreciated.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
structure ( ) posted Thu, 09 January 2014 at 5:54 PM · edited Thu, 09 January 2014 at 5:57 PM
Forum Coordinator
I wrote this a while ago and it seems to work ok, I was kinda hoping someone had a better solution though.
import poser
scene=poser.Scene()
for act in scene.Actors():
    if act !=None:
        if (not act.IsBase()) and (not act.IsDeformer()) and (not act.IsZone()) and (not act.IsLight()) and (not act.IsCamera()) and (not act.IsBodyPart()):
            try:
                if act.Parent().InternalName().lower()[0:4]=='head':
                    print 'probably hair', act.Name(),'n'
                if act.ConformTarget().lower()[0:4]=='head':
                    print 'probably hair', act.Name(), 'n'
            except:
                pass
Locked Out
Pret-a-3D ( ) posted Thu, 09 January 2014 at 6:07 PM
Thanks.
I got a reply from SM in the meantime that points out that all hair props have a Actor.InternalName() that starts with "figureHair". Sometimes the solution stares you in the face :)
Paolo
Tw: @preta3d
structure ( ) posted Fri, 10 January 2014 at 12:03 AM
Forum Coordinator
good to know lol :)
Locked Out
