Wed, Feb 26, 9:14 PM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom
Freestuff F.A.Q (Last Updated: 2025 Feb 23 8:26 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Free "Gargoyle" Walking Cane
LuxXeon ( ) posted Thu, 27 March 2014 at 10:01 AM · edited Wed, 26 February 2025 at 6:04 PM
Attached Link: Walking Cane (OBJ Version)
An ornate walking cane, with hardwood shaft, and solid metal "gargoyle" handle, metal junctions, and rubber tip.  This model is built entirely of quad polygons and subdivisonal modeling techniques, and consists of 14,878 total polygons, and 15,112 vertices. The model has been UV unwrapped, and comes complete with diffuse, specular, gloss, and bump maps for each subobject material zone; however, you can use your own seamless procedural materials instead, if you desire.  There are 6 subobject elements to this model; each of which can be assigned it's own unique material.  I recommend using the maps provided as a basis for a reflective brass material, with worn edges, as seen in the example renders of this object.  All of the preview renders were done with exactly the same texture maps provided with the model, using the Octane render engine, and Octane's glossy materials.  The specular maps are intended for use in a reflection channel, and the glossy maps can be used in an appropriate channel to blur the reflections.  Each texture map was created to 2048x2048, which should be suitable for most close-up rendering.
The model is available as a native .max scene file, compatible with 3dsmax 2012 or higher.  It is also available in several scale-specific OBJ files, for use in other applications, like Blender, Poser, or Daz Studio.  Most OBJ users will need to load the reflection and glossy maps manually in their software, as the export/import options of the OBJ will not automatically load them with the model.  ***OBJ Users, please refer to the instructions below for specific direction on how to load this model into your scenes.
Click Here to get the OBJ Version
Click Here to get the MAX Version
Alternatively, you can also download this model from the following resource websites, as well as view more production renders and wireframes:
Turbosquid.com
** ShareCG.com**
You are free to use or modify this model as you see fit for your own projects or scenes. As with all my freebies, this model can be used for both commercial and non-commercial renders. You may NOT, however, resell or redistribute these models or textures, or any derivative of them; individually, or as part of a package/set.
*** OBJ USERS: There are 3 different OBJ files, and one MTL file for this model. You will notice that two of the three OBJ files are labeled for specific applications (Poser and Blender). It's recommended to use these in the specific application. POSER USERS: The OBJ with (POSER) suffix was exported with a scale conversion that will allow the object to load with appropriate scaling into Poser 9 and above, or Daz Studio 4 and above, with Poser import settings. To import this file into Poser, please BE SURE to DE-select all the check box options in the OBJ Import Options dialogue box. DESELECT the "Centered", "Place On Floor", "Percent of Standard Figure Size", etc. so that no options are checked. This will import the object exactly as intended into the scene, with proper scaling. DAZ STUDIO users: Select "File/Import", then navigate to the folder on your hard drive that contains the model in this pack. Choose the "(POSER).obj". In the Import Options dialogue box, pick the Poser (1unit=8ft) option in the "FROM" dropdown list. Be sure all other options are checked, and click "Accept". BLENDER USERS: Select the "(BLENDER).obj". All other software packages should import the standard "walking_cane.obj" without specific suffix.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
ThunderStone ( ) posted Thu, 27 March 2014 at 1:06 PM
Thanks... Have you faved on another site... Thanks for sharing!
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Alisa ( ) posted Thu, 27 March 2014 at 1:30 PM
Very cool - thanks!
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
zandar ( ) posted Thu, 27 March 2014 at 7:35 PM
Very great model!  Thankyou!
