Sun, Dec 1, 1:24 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: Rendering/Shaders(?)
lustfulshadow ( ) posted Sun, 19 October 2014 at 1:33 PM · edited Wed, 17 July 2024 at 7:56 PM
Am looking to create the glossy amazing lips that Echo has..
http://www.daz3d.com/echo
Any idea where to begin? I'm pretty new still so. :(
SickenlySweete ( ) posted Mon, 20 October 2014 at 2:38 AM
Go to lips in the surface tab and play with the glossy setting and the spectral one.
www.bloodyrosesdesigns.com
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
lustfulshadow ( ) posted Mon, 20 October 2014 at 3:57 AM
Quote - Go to lips in the surface tab and play with the glossy setting and the spectral one.
Neither seem to be doing anything. :/
http://gyazo.com/ccb1f1b722bc0e0b4686e00dd4b6b0dc (Dont mind the really bad quality, I didnt render it for more then a minute or so.)
No matter what I do it just seems to be this "Matte" - I'm using LuxRender mind you.
RHaseltine ( ) posted Mon, 20 October 2014 at 9:47 AM
How are you getting the content into LuxRender - Reality, Luxus or manual import from OBJ or the like?
Medzinatar ( ) posted Mon, 20 October 2014 at 10:21 AM
First of all, make sure your material settings are not being overridden by one of the ACSEL shaders.
If you have the default ACSEL for Genesis installed, what you do in surface tab won't have any effect on render.
The shader for Echo uses a light purplish blue for the specular color, so that should be starting point for Lux material.
lustfulshadow ( ) posted Mon, 20 October 2014 at 5:19 PM
Hrm I see, i'll start tweaking and the like.
I'm using Reality.
Medzinatar ( ) posted Mon, 20 October 2014 at 5:31 PM · edited Mon, 20 October 2014 at 5:32 PM
I hadn't used Echo in Lux before (just 3Delight), so thought I would check it out. Keep in mind that the base texture plays an important role, in some cases more than any tweaks you might do on the shader.
lustfulshadow ( ) posted Mon, 20 October 2014 at 5:36 PM
Quote - I hadn't used Echo in Lux before (just 3Delight), so thought I would check it out.
Nods I see, What do you suggest I do?
Medzinatar ( ) posted Mon, 20 October 2014 at 6:09 PM · edited Mon, 20 October 2014 at 6:10 PM
I do not know your skill level, so is hard to making suggestion. Luxus and Reality handle material different and I don't know what you are using.
You should see tutorial on how Luxrender materials work with whatever exporter you are using.
Luxrender is a physically correct system, so lighting and color of surrounding objects influence as in real world.
To gain intuition of scene you must do many mistaken ones to see effect of changes.
I do this one, changing hair color and face morph but keeping most skin texture and shaders.
I think change can be called significant.
