Fri, Nov 29, 3:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: M4 V4 Poser 2014 Pro
vitachick ( ) posted Wed, 05 November 2014 at 7:13 AM · edited Fri, 29 November 2024 at 3:31 AM
Having problem importing previous saved M4 V4 characters....Screen is just blank..
When I open Daz People M4 etc figure shows on screen..Non of the body morphs.
Re-import....Now problem is when I try to save...See screen for error....
It did work at one time since I have alot of M4 V4 items saved but will not
open..
Anyone else having this problem?  If so how to correct..
file_b73ce398c39f506af761d2277d853a92.JP
Win10  Poser 2014/Poser 11 Daz3D
hornet3d ( ) posted Wed, 05 November 2014 at 7:34 AM
 I have Game Dev on Win 7 ultimate and have not seen the problem.  Your Screen save image shows Poser  running the 32bit version.  Do you have the same problem with the 64bit.
Where are your runtimes located?  Is Poser the only one having problems if not you may have a disk beginning to fail.
vitachick ( ) posted Wed, 05 November 2014 at 7:50 AM
Only problem is with Poser2014...Daz 4.6 I am able to import etc....Yes
problem is with my Win XP 32 bit comp...Dunno is any update did it?
Annoying since I have so much saved...BTW problem also with all V4 I saved...
My other comp has Win7 with NP...
vitachick ( ) posted Wed, 05 November 2014 at 7:51 AM
My runtimes are all on external drive...Have Poser runtime /Daz content there
DarwinsMishap ( ) posted Wed, 05 November 2014 at 8:58 AM
The importing is confusing me- are you importing a poser/studio scene into poser or trying to get the M4 from your Poser or Studio runtime library?  I haven't had this issue when importing a scene from Studio to Poser 10, nor using a saved character of M4 from my Character runtime library.  Odd.
vitachick ( ) posted Wed, 05 November 2014 at 9:05 AM
Just trying to save M4 to my desktop folder...I opened it fresh from Daz People folder.
Unable to import anything previously saved for M4 for V4
vitachick ( ) posted Wed, 05 November 2014 at 9:10 AM
You can see I have quite a lot for M4...The screen shot is Poser is what I get when I
try to open...The other screen shot shows when I start from scratch and try to save
vitachick ( ) posted Wed, 05 November 2014 at 9:13 AM
file_5fd0b37cd7dbbb00f97ba6ce92bf5add.JP
RHaseltine ( ) posted Wed, 05 November 2014 at 9:22 AM
Is Edit>General Preferences>Miscellaneous>Use External Binary Morph targets on? If it is, turn it off and try saving and then reloading a new scene.
vitachick ( ) posted Wed, 05 November 2014 at 9:50 AM
That seemed to fix 99%...Some saved items I get the same..
Thank you....
MatCreator ( ) posted Wed, 05 November 2014 at 3:13 PM
RHasletine is like awesome... Dewd walks in james bond style with one line of text and ShaBam!!! problem solved... Fixes his tie and collar, pulls down his sleeves from his sports jacket and walks out the room...
and yes... drives a jaguar.
There are 3 kinds of people in the world. Those that can count, and those that can't..
vitachick ( ) posted Wed, 12 November 2014 at 5:48 AM
Back again...I noticed when I checked my saved M4 some do not have two icons..
file_da4fb5c6e93e74d3df8527599fa62642.JPOne is poser scene and other poser content...Any one have any idea why this happened?  Guess I will have to delete all that only have poser scene icon
vitachick ( ) posted Wed, 12 November 2014 at 5:54 AM
PS..Unable to delete icons that only show only PoserScene content icon..Get error file is in use...
hornet3d ( ) posted Wed, 12 November 2014 at 7:39 AM
 I believe I am correct in saying that the only time you get two icons is if you have the external binary morphs ticked.  With external binary morphs un-ticked you get one icon.  Not sure why Windows will not let you delete unless it is protected.
Despite the fact that many have no problems with the latest versions of Poser I have not used external binary morphs since Poser 7 as I had the problem you have seen here.
vitachick ( ) posted Wed, 12 November 2014 at 7:46 AM
Hmm so this is a mystery..Using my Win XP 32 bit comp..My favorite..
Guess I'll just live with it.
Thanks for you help and time..
hborre ( ) posted Wed, 12 November 2014 at 8:30 AM
There is an unlock app that will disassociate the files from their parent program.  ATM, I am not currently sitting at my home computer to extract the exact application name.  It is a freebie, though.
vitachick ( ) posted Wed, 12 November 2014 at 8:51 AM
I saw the program online but it's for Vista/Win 7...Not Win XP..did not want to install until I
was sure it would work
moriador ( ) posted Wed, 12 November 2014 at 3:22 PM
You could try reloading each scene that has the dual files and then resaving it. Time consuming, indeed. But since I believe that secondary file contains the morph information, if you just delete it, won't you lose the data permanently? Unless you've saved it in a new scene while having "Use external binary morphs" check off?
vitachick ( ) posted Wed, 12 November 2014 at 3:39 PM
Items with the dual files load ok...Its the icons that only have PoserScene that will not load. I have 10+ of
them..Just more annoying then anything else.
moriador ( ) posted Wed, 12 November 2014 at 4:35 PM
Hmmm. I find that odd. I wonder if they used to have matching files that somehow got deleted? Then again, I can't say I know much about the subject, alas.
vitachick ( ) posted Wed, 12 November 2014 at 4:40 PM
Agree its odd and I'm able able to delete as error says files are being used...
hborre ( ) posted Wed, 12 November 2014 at 6:30 PM
http://www.emptyloop.com/unlocker/
Works with XP, I have this loaded on an XP machine.
vitachick ( ) posted Thu, 13 November 2014 at 4:39 AM
See attached pic..Win XP blocking install
file_202cb962ac59075b964b07152d234b70.JP
vitachick ( ) posted Sat, 15 November 2014 at 11:14 AM
Help!!!!!!!!!!!!!!!!!
structure ( ) posted Sun, 16 November 2014 at 3:58 AM
Forum Coordinator
the files with grey Icons are .PMD files (external Binaries) are these the ones you cannot delete?
if so, have you tried deleting them while poser is closed?
were they created under another username?
as for the blocking of the install, that looks like Firefox is blocking it(that can be changed in your settings), navigate to the containing folder and try launching the installation from there.
Locked Out
vitachick ( ) posted Sun, 16 November 2014 at 7:44 AM
.exe is in my document folder....
As for deleting the unwanted items even  my online tech support could not do it...The red icons  shown in this folder. M4 also has some
file_0f28b5d49b3020afeecd95b4009adf4c.JP
