DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
UVs move with the geometry - they points that define the shape are pinned to the texture map. If you want the model to move and the map to slide over the surface you need a projective mapping, which isn't available n DAZ Studio (though to an extent you could make your own in Shader Mixer - however the only examples I can think of are planar, the Shades of Life sets, which act like a slide-projector shining onto the model - if you wanted a pattern to have more repeats around part of a mesh that was enlarged that would require a more elaborate approach, and might not be possible with the available tools).
Looks to me like you need a better UV mapping tool. I'm no expert on this but I use the one in Blender (its free) - the one in Blacksmith is supposed to be better as it can even up the edge distortion effects . . . . . but I haven't got it to work.
In Blender the UV mapping tool has several options which would give you a more correct result than that shown. Like most things it depends on how much time you want to spend on it.
Yes thats a uv map problem not a studio one.
Hedus uvlayout works great.
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
here sometimes image can not be sent for why,
what image accepted here
do uvmap but always bend how to adjust
