Wed, Feb 26, 9:33 PM CST
Forum Moderators: RedPhantom
Subject: figure install proiblems.
tinman_prime ( ) posted Sun, 01 February 2015 at 2:45 AM · edited Wed, 26 February 2025 at 9:23 PM
Hello,
I use poser 8 and am trying to install a DAZ model for V4. The installation  goes on without any problems. When I open Poser, everything is is there. However when I go and try and load it to add to V4, it says loading and there is the little timer spinning. That’s it. Nothing appears. I check the directories and find everything in place. What is causing this?
Thanks
hborre ( ) posted Sun, 01 February 2015 at 7:34 AM
It sounds to me that you are trying to load a character file and don't have the necessary morphs packages to successfully complete the installation.  Check the specs in the content readme text and verify that you have the additional appropriate content installed before proceeding.  If you are lacking a morph package, you will need to purchase it from DAZ before you can use the model.
tinman_prime ( ) posted Sun, 01 February 2015 at 3:16 PM
Thanks, I check it out.
